Page 1 of 3 1 2 3
Removal of Lower Control Arm Bushing - Any tricks ???? #470829
09/17/09 11:43 AM
09/17/09 11:43 AM
Nebraska
RaceCarRegistry Offline OP
super street
super street
Nebraska
Any suggestions for removing "stuck" lower control arm bushing ?? Trying to build my 64 Savoy Wagon susp but these bushing are giving me troubles.
Many Thanks, Reed in Neb.
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: RaceCarRegistry] #470830
09/17/09 11:50 AM
09/17/09 11:50 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
They arn't much fun. It look a lot of work getting them out on my 73 Challenger. I have heard that you can weld a thick washer onto the outer bushing sleeve. That will give you something to "press" against. That didn't work for me. I had to use an air chisel and muscle them out.
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: RaceCarRegistry] #470831
09/17/09 05:30 PM
09/17/09 05:30 PM
Southeastern MI.
Q
QuickSilver Offline
mopar addict
QuickSilver  Offline
mopar addict
Q
Southeastern MI.
Hey there Reed, . Welcome to the lower control arm blues! Man those things are in there. Some you would almost swear that they are permanent. So far the best method I have found is to have the lower control arms sent out to the metal cleaners, redi strip ,etc. Usually once they come back the bushing itself is gone then all I do is take a very small chisel and get the outer edge of the old sleeve to start caving in on itself. After you do get it started I then take a carbide bit and make a small incision in the side of the sleeve and simply chisel it out of the bushing bore. If you don't have access to the metal cleaners you must knock out the rubber bushing first and then work on the left over steel sleeve. Either way it is a fair amount of work. Hopefully this helps. Maybe some one out there has a better plan. My buddy used one of the tools available to remove the rubber but it still leaves the sleeve behind. Good Luck. JC
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: QuickSilver] #470832
09/17/09 05:44 PM
09/17/09 05:44 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
How bout a machine shop?
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: rayztoy] #470833
09/17/09 06:00 PM
09/17/09 06:00 PM
Smyrna,TN.
cudagregs Offline
cudagregs  Offline
Smyrna,TN.
My buddy and me used the old air chisel too. We cut a split on the end of the shell with a dremel tool. Then we split the shell with the chisel. It's no fun however you do it.
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: cudagregs] #470834
09/17/09 06:25 PM
09/17/09 06:25 PM
Nebraska
super street
super street
Nebraska
Thanks for all the input folks - I've tried all the suggestions before, but was hoping someone had come up with a "miracle cure" - Never hurts to ask - Reed in Neb.
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: RaceCarRegistry] #470835
09/17/09 07:05 PM
09/17/09 07:05 PM
Olympia WA
rocketresto Offline
rocketresto  Offline
Olympia WA
If you have acces to a press and welder, the welded washer trick works great. Most front shock washers are the correct size to weld to the shell in the control arm, don't be afraid to really cook the weld so they stay together. I use a cutoff wheel to split the sleave off the pin, with this method I can have a pair apart in less than half an hour.
mike
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: rocketresto] #470836
09/17/09 07:17 PM
09/17/09 07:17 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
mike
same here , I weld in 1/2" steel flat washer , just the right size and then use a threaded rod and nut to push it out in the press , never had onenot come out , just be careful you don't weld the shell to the control arm ...
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: JohnRR] #470837
09/17/09 10:38 PM
09/17/09 10:38 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Removed the center rubber and sleeve then took a diamond shaped chisel, knocked the top overhang lip in, then drove the chisel down the inside a little. Used a screwdriver and the chisel/drift to collapse the bushing and out it came...
MikeR
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: A12] #470838
09/17/09 10:40 PM
09/17/09 10:40 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
another view
Re: Removal of Lower Control Arm Bushing - Any tricks ? [Re: RaceCarRegistry] #470839
09/17/09 10:46 PM
09/17/09 10:46 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I used the American Muscle lower control arm pivot remover. Got it from Mancini, I think.
http://www.myspace.com/americanmusclellc
Worked well, not easy but still worked well.
Craig
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: rocketresto] #470840
09/17/09 11:02 PM
09/17/09 11:02 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
mike
IMPORTANT...........
don't just tack a couple of the sides of the washer. with that i just beat the washer off the sleeve. i had to almost weld the washer completely on the outer sleeve. worked like a charm but i wouldn't say it was as easy as pie
OH...... P.B Blaster helps too
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: A12] #470841
09/17/09 11:59 PM
09/17/09 11:59 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
MikeR
YEP....That's exactly how I do it....Ive got it down to about 20 mins for a pair. You need a good press and an air chisel
CHECK OUT MY NEW WEB SITE !
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: RaceCarRegistry] #470842
09/18/09 02:36 AM
09/18/09 02:36 AM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
the best way ive found done over 50 sets, is take mopar bumber bolts 66-74 with the built in washer fits perfect size of shell, drop it in lca shell flush bolt toward t-bar hex. four tack welds then pump them right out with my otc ball joint pressed operated with impact gun. just did them in my 68 hemi charger left no marks on lca pocket, air chisel is kinda hacky, watch out for press it loads up lca flanges to much and might bent them
MOPAR OR NO CAR
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: hemigod426] #470843
09/18/09 03:11 AM
09/18/09 03:11 AM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
They way I did them I only used hand tools, no air chisel, no welder, no press......yep your basic hammer, chisel and scerwdriver, shade tree hack engineering
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: A12] #470844
09/18/09 03:19 AM
09/18/09 03:19 AM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
oops almost forgot had to use one of those squeezey, clamping thingies; a vise, my 10-year old just couldn't hold that LCA steady enough
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: A12] #470845
09/18/09 08:46 AM
09/18/09 08:46 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: burdar] #470846
09/18/09 08:23 PM
09/18/09 08:23 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
I dig the inner sleeve and rubber out, then cut the outer with a torch. Does no damage to the arm if youre good with a torch. I have them down to about 10 minutes per bushing.
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: 69L78Nova] #470847
09/20/09 12:59 AM
09/20/09 12:59 AM
NM
74fish Offline
74fish  Offline
NM
I use the washer and press but I put the washer inside after digging the rubber out. You can also use a torch to burn the rubber out. Works great.
Re: Removal of Lower Control Arm Bushing - Any tricks ? [Re: 74fish] #470848
09/20/09 02:58 AM
09/20/09 02:58 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
thats the way i do it too///light the rubber on fire
Page 1 of 3 1 2 3
