Page 1 of 3 1 2 3
340 vs 360 class racing #470697
09/17/09 10:15 AM
09/17/09 10:15 AM
indiana
mrart01 Offline OP
mrart01  Offline OP
indiana
All things being equal would the 340 keep up or b faster than the 360,we know the 360 has a longer stroke but also has the smaller bore
Re: 340 vs 360 class racing [Re: mrart01] #470698
09/17/09 10:52 AM
09/17/09 10:52 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Just guessing
Both engines legal in the same weight car......360
Re: 340 vs 360 class racing [Re: S/ST 3040] #470699
09/17/09 11:11 AM
09/17/09 11:11 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
We have run both blocks with the same heads cam, intake and exhaust in the same truck, The 360 is stronger
Re: 340 vs 360 class racing [Re: emarine01] #470700
09/17/09 01:25 PM
09/17/09 01:25 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I would prefer a 360 for the street or mild builds. No substitute for cubic inches, a wise man once said. I think by the time you get to an all out engine, W9 heads, roller cam, etc., the difference diminishes as the intake, carb and cam start limiting the power. You would just spin the 340 a little more RPM than the 360. Does anyone still build a stock displacement engine anymore?
Floyd Lippencott IV
Re: 340 vs 360 class racing [Re: mrart01] #470701
09/17/09 01:29 PM
09/17/09 01:29 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
It is alot closer than you would think.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: 340 vs 360 class racing [Re: mr_340] #470702
09/17/09 01:31 PM
09/17/09 01:31 PM
new jersey usa
11secdart Online content
11secdart  Online Content
new jersey usa
I ran 340s for many years before switching to a crate 360 short block a few years ago, My 340s ran good in the 10s and over 500 hp but the 360 made more torque and pulls better in high gear with the same cam, comp.ratio and W2 head setup.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: 340 vs 360 class racing [Re: 11secdart] #470703
09/17/09 01:41 PM
09/17/09 01:41 PM
340...............
Re: 340 vs 360 class racing [Re: mr_340] #470704
09/17/09 02:11 PM
09/17/09 02:11 PM
S/ST 3040 Offline
S/ST 3040  Offline
.............I'm a late bloomer.
Re: 340 vs 360 class racing [Re: mr_340] #470705
09/17/09 02:13 PM
09/17/09 02:13 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
sure im building a .030 over 340 with stock stroke right now and there is a few good reasons for it in my case but im not realy classracing.. it will hopefully be alitle quicker than most stock stroke 340s around here,and i think it may even be capable of give most stroker smallblocks a real good run for the money also
Re: 340 vs 360 class racing [Re: 1Fast340] #470706
09/17/09 05:49 PM
09/17/09 05:49 PM
Down South
DaKuda Offline
DaKuda  Offline
Down South
340 all the way. My '72 Cuda with a roller cam 340 and ootb Edelbrock heads went 6.71 in the 1/8th shifting at 6000. Tuff engine.
Re: 340 vs 360 class racing [Re: 1Fast340] #470707
09/17/09 05:55 PM
09/17/09 05:55 PM
CheddarHead till October
weedlayer Offline
weedlayer  Offline
I may be a Swede, but am not in Sweden, so I guess I'll have to pass on that challenge.
Re: 340 vs 360 class racing [Re: weedlayer] #470708
09/17/09 06:31 PM
09/17/09 06:31 PM
nc
moeflo Offline
moeflo  Offline
nc
The only reason to use a shorter stroke motor is, you already have one, or you need the most HP per CI. Other than that, build with plenty of stroke and your valve train will thank you.
Re: 340 vs 360 class racing [Re: S/ST 3040] #470709
09/17/09 06:54 PM
09/17/09 06:54 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
That would be me also. My 63 has a stock stroke 440 and my sons Dart a stock stroke 400. I feel like a loner. Ron
Re: 340 vs 360 class racing [Re: 383man] #470710
09/17/09 07:59 PM
09/17/09 07:59 PM
My 360 is stock stroke and has gone 11.79..but i do miss my stroker...
Re: 340 vs 360 class racing [Re: mrart01] #470711
09/17/09 08:01 PM
09/17/09 08:01 PM
Locomotion Offline
Locomotion  Offline
There are a lot of variables within 340's as well as 360's in Stock and SS, so it boils down to "it depends".
'71 high compression 340's with a TQ tend fit and run in slightly faster classes than the other 340's and 360's. The '74 360 is right behind it, but they are used in heavier cars. Then it appears that the AVS 340's and later 360's run is several of the slower classes after that. Car weights vary quite a bit. In Stock, this tends to be spread out from D/Stock up through K/Stock or around there. Basically mid-10's through high 11's.
Moparts member Elephuntman had the C/SA record with a 340 Six Pack Challenger T/A in the 10.30 range at one time!!!
There is no substitute for cubic inches, so, all else being equal, a 360 will be faster. It would be intersting to do some research and see what the average '71 340 would run against the average '74 360 at the same weight.
I'm sure somebody more familiar with the class weights and ET's would know already
Re: 340 vs 360 class racing [Re: Locomotion] #470712
09/17/09 09:19 PM
09/17/09 09:19 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
From experience a 340 compression engine makes the most power, TQ & AVS, by a good margin. A low compression 340 is not that far off of a 74 360. The 360 has more power down low but it does not have the rpm ability so on the track they are not that far apart. In Super Stock things get closer all the way around.
1959 Bugeye Sprite
1971 MG Midget
Re: 340 vs 360 class racing [Re: sixpackbee] #470713
09/17/09 09:28 PM
09/17/09 09:28 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
Herb McCandless told me that he found the 360 to be better in his son's S/S Lebaron. He said they took the cam, heads, intake, etc. and installed them on a 360 short block and that the car ran better. Maybe Herb Jr. can chime in on this...
Re: 340 vs 360 class racing [Re: emarine01] #470714
09/17/09 09:38 PM
09/17/09 09:38 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Both engines were +.030 zero deck kb 107s , the 360 block was .125 ave faster with everything else being the same
Re: 340 vs 360 class racing #470715
09/17/09 11:04 PM
09/17/09 11:04 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
340...............
Not happening
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: 340 vs 360 class racing [Re: 69L78Nova] #470716
09/18/09 03:39 AM
09/18/09 03:39 AM
340...............
Not happening
Oh ya'..all depends on who builds it..
Page 1 of 3 1 2 3
