Did a windage tray save my engine???
#470644
09/17/09 12:59 AM
09/17/09 12:59 AM
Posts: 1,281 wisconsin
kmfdm
wisconsin
I've posted before about having a weird oil pressure issue where it builds pressure at start up, then rapidly drops and fluctuates. It doesn't matter if I'm revving it or not. Last time it did this I found the issue to be a loose oil pick-up ( its a 360 by the way). I figured I must have messed up so I just replaced the pump and made sure the pick-up was tight. I thought I had the problem fixed, but after 30 miles of running, the problem came back. Finally today I got around to dropping the pan and checking the pick-up again. I found the pick-up pressed up tight against the bottom of my windage tray!!!! First, how in the hell does an oil pick-up spin itself up against gravity? Second, does Milodon warranty any of their stuff?? Third, if the windage tray wasn't there, do you think the pick-up would have hit the crank or a rod and really done some damage?
74 Dart Sport
Re: Did a windage tray save my engine???
[Re: stumpy]
#470646
09/17/09 11:23 AM
09/17/09 11:23 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Sounds more like the pickup was loose and the pump started sucking air around the threads too. It's pipe thread so it has to be really tight to seal and stay put... Sounds like what was said. You are not tightening it enough.
[Re: moper]
#470647
09/17/09 03:17 PM
09/17/09 03:17 PM
kmfdm
wisconsin
There's no way I could tighten it anymore without breaking it. I ordered another one so maybe I'll do a little experiment with the old one.
74 Dart Sport
[Re: kmfdm]
#470648
09/17/09 03:35 PM
09/17/09 03:35 PM
Posts: 2,826 NY usa
540challenger
NY usa
If you can't tighten any more i would check the thread on the pump,If everything turns out good and you want added insurance i have seen guys tack weld the pick up.
Also when you found dropped the pan could you move the pick up by hand??
[Re: kmfdm]
#470650
09/17/09 05:00 PM
09/17/09 05:00 PM
Posts: 6,516 Santa Cruz, California
Lefty
A little tack weld will keep it in place.
