mini starter wires #470578
09/16/09 10:45 PM
09/16/09 10:45 PM
Indiana
65dragnet Offline OP
Indiana
does anybody make a disconnect or a pig tail for a mini starter? I have a mini on my 440 and the wires are a p.i.t.a. to connect or disconnect , being they are so close to the block.
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Post deleted by Defbob [Re: 65dragnet] #470579
09/16/09 11:24 PM
09/16/09 11:24 PM
Re: mini starter wires #470580
09/16/09 11:34 PM
09/16/09 11:34 PM
Indiana
Indiana
thanks fred !
Post deleted by Defbob [Re: 65dragnet] #470581
09/16/09 11:50 PM
09/16/09 11:50 PM
Re: mini starter wires #470582
09/17/09 12:38 AM
09/17/09 12:38 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
no cost option, tighten the wires up before you bolt it position. thats what i do.
Re: mini starter wires [Re: rebel] #470583
09/17/09 01:07 AM
09/17/09 01:07 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
There ya go...
Re: mini starter wires [Re: 64Post] #470584
09/17/09 10:35 AM
09/17/09 10:35 AM
Indiana
Indiana
That's what I do also , but I was asking for a friend who has an A body big block and pro part headers and he's having problems with the wires. I thought I would ask if something was available like a plug in or pigtail arrangement. Thanks guys , didn;t find anything from Moroso.
Re: mini starter wires [Re: 65dragnet] #470585
09/17/09 10:50 AM
09/17/09 10:50 AM
NW PA
V10nacuda Offline
V10nacuda  Offline
NW PA
Not sure if your starter has the extension block mounted to it... But on both applications I used the mini starter for I removed the bakalite & copper extension & there was more room & was easier to route the wires..
V10
Re: mini starter wires [Re: V10nacuda] #470586
09/17/09 10:13 PM
09/17/09 10:13 PM
Indiana
Indiana
oh yes the adapter was removed.
Re: mini starter wires [Re: 65dragnet] #470587
09/17/09 10:38 PM
09/17/09 10:38 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
One other thing that might help,......
on mine I ran a small jumper that I made between the two terminals on the starter.Then used a Ford type solenoid on the firewall.This way there is only one (heavy) wire to the starter,and it is only hot when cranking.So in the event it does burn on the header,you don't short a main hot lead while it is running.
