Re: 67 Fury with a 4 speed ?
[Re: Scatpak]
#470506
09/16/09 11:05 PM
09/16/09 11:05 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
Could you get a 4 speed in a 67 Fury ? Also I heard it has a 318. If it came like this, does anybody know production #'s?
You might want to ask for documentation or take a look at the fender tag. A three speed was standard. The 318 4 speed combination was not supposed to be available. Maybe it was a 383 and the engine was changed or a three speed and the transmission was changed.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: Scatpak]
#470508
09/19/09 12:46 AM
09/19/09 12:46 AM
Posts: 1,107 Spring Valley ,Ca.
moparsquid
Spring Valley ,Ca.
if the 318 was not available more likley it was a 273 common mistake to confuse the two.
