Heater core housing #470070
09/16/09 02:06 PM
09/16/09 02:06 PM
Elk Grove, Calif.
bigblock340power Offline OP
Elk Grove, Calif.
I have my Heater core housing out of the car. I've got another one (H C housing) for parts to put the two together as a good one. The problem is both have bad (how do I put this) card board backing/venting. It's the piece that clips to the back of the H C housing between the housing and the fire wall (inside the car), then vents on top of the trans tunnel hump up front, in front of my console, for blowing hot air on your feet or ?. Looks like I could just take it off and trace it out on something. But what do I use? Anybody?
Thanks,
Mike
Re: Heater core housing [Re: bigblock340power] #470071
09/16/09 04:13 PM
09/16/09 04:13 PM
Elk Grove, Calif.
Elk Grove, Calif.
Someone please.
Re: Heater core housing [Re: bigblock340power] #470072
09/16/09 04:47 PM
09/16/09 04:47 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Not part of the heater core rebuild kits on ebay etc????
Re: Heater core housing [Re: Neil] #470073
09/16/09 05:05 PM
09/16/09 05:05 PM
okla.
O
okie Offline
okie  Offline
O
okla.
If it is the black colored paper deflecter you can get them new off e-bay, and James Filmore on here might have them since he sells the rebuild kits for heater boxes. I would think he would have them. Good Luck! Ronnie
Re: Heater core housing [Re: okie] #470074
09/16/09 06:34 PM
09/16/09 06:34 PM
Elk Grove, Calif.
Elk Grove, Calif.
Thanks everyone, found everything I needed on E bay (DMT). Bought it all and its on it's way. I don't know why I didn't think of E bay before. But then that's what we're all about, helping each other. I did go to joanns earlier today and found some material that would work. But I'm going to take that back now.
Thanks again,
Mike
Re: Heater core housing [Re: bigblock340power] #470075
09/16/09 07:19 PM
09/16/09 07:19 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Thats me and THANKS for the order.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Heater core housing [Re: bigblock340power] #470076
09/16/09 07:22 PM
09/16/09 07:22 PM
Pizza Bucket
snuggles Offline
snuggles  Offline
Pizza Bucket
I found some at the local furniture store that rebuilds furniture.
Re: Heater core housing [Re: 71TA] #470077
09/16/09 08:28 PM
09/16/09 08:28 PM
Elk Grove, Calif.
Elk Grove, Calif.
Your welcome, now send the parts quick. No not really I still have some painting to do. But don't hold off.
Mike
Re: Heater core housing [Re: bigblock340power] #470078
09/16/09 11:28 PM
09/16/09 11:28 PM
Delaware shore
68Barracuda Offline
68Barracuda  Offline
Delaware shore
I've used DMT's kits. You are going to be blown away, super complete and fit like original parts. Wait until you get the kit to start assembly there will probably be some parts included that you wouldn't have exspected to get.
Good luck
