Dyno day for my 505 - Results are in AGAIN
#469914
09/16/09 10:58 AM
09/16/09 10:58 AM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Hey guys - just wanted to vent my excitement for the long anticipated dyno day tomorrow. I havn't had a running car for almost 2 years, so I'm really looking forward to gettin it on in the dyno room! Here's the combo and please post your guesses on the final outcome. You may want to wear your chinese parts glasses for this one! 440, +.030, 440 source 4.25 crank, h beam rods and 17cc dish pistons, 10.5-1 measured compression, stealth heads CNC'd at modern cylinder head, Comp solid flat tappet spec'd by Dwayne Porter 262/267 @ .050 .585/.602 lift w/1.5, 112 lsa, crane golds, isky springs, comp retainers and keepers, smith bros pushrods, Cloyes timing set, Holley SD intake, Quickfuel 950 annular carb, 1/2 pickup, melling hv pump and mopar 7 qt pan The engine shop has a set of 2 1/4 headers for the dyno, but I will have 2" in the car. I hope to have some results tomorrow night
2 kids and a dog
Re: Dyno day for my 512 - finally!
[Re: mopowers]
#469920
09/16/09 11:46 AM
09/16/09 11:46 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I'm thinking a lot more than 625 hp,,,,,,,,,,,
[Re: gregsdart]
#469921
09/16/09 11:51 AM
09/16/09 11:51 AM
Posts: 19,375 Las Vegas
Al_Alguire
Las Vegas
Tony,Good luck with the dyno day...I am sure you will be happy. I am gonna take a WAG and say 704/650..Looking forward to the results.
[Re: Al_Alguire]
#469922
09/16/09 12:09 PM
09/16/09 12:09 PM
Posts: 3,210 robin hood country
deaks
robin hood country
This is also what i'm looking to build, i've got edelbrocks done by modern but milled .050 and i'm looking at a roller in at 108. Do you get 10.5.1 with 84cc heads. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: deaks]
#469923
09/16/09 02:59 PM
09/16/09 02:59 PM
TonyS451
Chicago, IL
Greg - Dwayne didn't say. He actually recommended something a little bigger for max performance, but I talked him down in exchange for some better street manners! Mopwers - My goals and plans...well its a 72 Challenger all steel full interior street car with 4.10's, 295/65 drag radials, 3" exhaust, and 9 1/2" converter. I'm hoping for upper 10's, but I won't be legal anyhow (no cage). I need to make a decision on that one...As for why I chose solid Flat tappet vs solid roller. Mainly cost. Al - If this thing makes 700hp I will flip! Thanks for the positive vibes, man. Deaks - I get 10.5 w/82cc chambers. Pistons are a couple in the hole and gasket is .040
2 kids and a dog
[Re: TonyS451]
#469924
09/16/09 03:12 PM
09/16/09 03:12 PM
Posts: 6,295 U.S.
moparniac
U.S.
Guy I know stealth head setup but with more cubes and it made 610....
Early 70's 440 block (unsure of year) prepped for overhaul/rebuild. 440 source 543 balanced stroker kit: (.055 over) 4.375" bore 4.500" stroke Forged flat-top 2618 T-6 aluminum billet pistons. 4340 forged steel crankshaft 4340 steel rods, full floating .990" pins Clevite bearings Childs & Albert ductile iron plasma-moly file fit rings 440 source Stealth aluminum heads with full port job; 2.14/1.81" valves, 84 cc chamber size. Comp Cams (#953-16) valve springs Open: 456 @ 1.250" Spring Rate: 473 in/lb Coil Bind: 1.085 Cam Motion custom ground hydraulic roller cam: Lift: .540/.527 Duration: 240/245 @ .050 Lobe separation 110.2 Comp Cams: push rods, 10 degree super locks & retainers. Compression at 11.04:1 Hughes Engines 1.5 ratio cnc'd aluminum roller rockers, cryogenically treated. Hyd roller lifters. Milodon External oiling system with Melling HV oil pump. 440 Source 7 qt. aluminum oil pan 440 Source windage tray Carter HV mech fuel pump. SFI certified Chrome fluid damper Billet double roller timing chain Edelbrock Performer RPM aluminum intake manifold Pro Systems 1000 cfm carburetor, mechanical secondaries. Doug's (#D452) ceramic coated full headers. 2" primaries, 3.5" collectors.
Well I took the 543 stroker to the engine dyno for a break-in and tune. It was awesome and I am still grinning! The results were quite good. I have about 8 pages of test results, but the bottom line is: 610 horsepower @ 5400 RPM with 651 ft/lbs of hole stompin' torque!
Mopar Performance
[Re: TonyS451]
#469925
09/16/09 03:24 PM
09/16/09 03:24 PM
Posts: 16,928 NC
440Jim
NC
Your car headers will likely give more low end torque (below maybe 4500), but the larger dyno headers may give a touch more peak horsepower. (but they are likely too big for your application IMO) Too bad many car headers don't fit around the dyno.
I look forward to the results.
[Re: TonyS451]
#469927
09/16/09 07:07 PM
09/16/09 07:07 PM
Posts: 3,095 Idaho
Runner
Idaho
i think it will go high tens easy.....good luck !!
[Re: DaDart]
#469929
09/16/09 08:26 PM
09/16/09 08:26 PM
TonyS451
Chicago, IL
It's on the dyno and was getting all hooked up
sweet! thanks for dropping off the spring tool. I hope to see you tomorrow after work for the fun
WEDGIE - Very cool combo you have there. A real stump puller to the max! That thing must idle like a stocker with the mild cam and all those cubes. I like it
[Re: TonyS451]
#469931
09/16/09 09:13 PM
09/16/09 09:13 PM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
Yeah Paul PHJ426 bought the 508 and the heads that Chuck at Best Machine didfor me (see the tech Archives), but last I talked to him he bought a Primo Black 70 440 Cuda so I think he back-burnered the Road Runner Stroker project. Well when you get her running just get a hold of me and you can borrow my old ported SD,...the runners are around 3.25 sq in (about 15% bigger than the standard 906 window) so it's really too big to work with a standard Valley pan port, You'd have to cut the Gaskets special and seal the valley. I bet I could have pretty much filled a super big gulp cup with all the aluminum that came out of that thing. I'm trying to remember, your other motor was a low deck 4.25 crank, right? the one with the Stage VI's and the Indy dual-plane? btw....your 512 I think (if it's .030 over) is "only" a 505 Good luck Tony!!
