DOT 3 and DOT 4 brake fluid question #469613
09/15/09 10:59 PM
09/15/09 10:59 PM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
I normally use DOT 3 brake fluid. A friend gave me some chemicals and in it was a bottle of DOT 4 brake fluid. Are the types compatible with each other?
Re: DOT 3 and DOT 4 brake fluid question [Re: SPWC] #469614
09/15/09 11:00 PM
09/15/09 11:00 PM
Winnipeg, MB
sreinheimer Offline
sreinheimer  Offline
Winnipeg, MB
Yep DOT 4 has a higher boiling point thats all
69 Dodge Charger - first full resto 05 Dodge Magnum R/T
Re: DOT 3 and DOT 4 brake fluid question [Re: sreinheimer] #469615
09/15/09 11:05 PM
09/15/09 11:05 PM
Kirkland, Washington
Pacnorthcuda Offline
Completely compatable. These days I see no reason to ever buy DOT3 again (haven't bought it in many years, never bought silicone DOT5) just my preference
Re: DOT 3 and DOT 4 brake fluid question [Re: Pacnorthcuda] #469616
09/16/09 12:14 AM
09/16/09 12:14 AM
colorado
chargermop Offline
chargermop  Offline
colorado
Do not use it if its been opened brake fluid is hydroscopic sp? and will soak up moisture from the air. Never buy more than you need, toss and left overs
