What are the differences between 68 and 69 340's #469601
09/15/09 10:34 PM
09/15/09 10:34 PM
Belleville Il
Dingmaster Offline OP
Belleville Il
I'm looking to find pics of correctly restored 340's for 68 and 69. Or post the visual differences between the two years. like air cleaner and valve covers.
Re: What are the differences between 68 and 69 340's [Re: Dingmaster] #469602
09/15/09 10:47 PM
09/15/09 10:47 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
COLOR:
1968 - RED
1969 - TURQUOISE
Air Cleaner:
all 1968 & 1969 340 are the same
Re: What are the differences between 68 and 69 340's [Re: Dingmaster] #469603
09/15/09 10:50 PM
09/15/09 10:50 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
The 68 drivers side exhaust manifold heat shield gasket is 1968 ONLY
Re: What are the differences between 68 and 69 340's [Re: gtx6970] #469604
09/15/09 11:07 PM
09/15/09 11:07 PM
Belleville Il
Belleville Il
Bill,
do you have a pic that shows how the heat shield is different?
Or was the heat shield 68 only?
Re: What are the differences between 68 and 69 340's [Re: Dingmaster] #469605
09/15/09 11:16 PM
09/15/09 11:16 PM
Belleville Il
Belleville Il
Is this a 68 340?
It seems the air cleaner has a smooth finish and the tube comes out in front of the breather. Could be the same just mounted different?
Also the valve covers look like regular 318 covers.
Re: What are the differences between 68 and 69 340's [Re: Dingmaster] #469606
09/15/09 11:26 PM
09/15/09 11:26 PM
Belleville Il
Belleville Il
Here's the 69 340 I plan to put in my 68. I just want it to look correct for 68.
Re: What are the differences between 68 and 69 340's [Re: Dingmaster] #469607
09/15/09 11:48 PM
09/15/09 11:48 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Red paint & '68 valve covers are the biggest visual differences you will encounter.
Re: What are the differences between 68 and 69 340's [Re: 6bblgt] #469608
09/16/09 12:17 AM
09/16/09 12:17 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
In addition to what's already been posted, the carb numbers and the 1968 manual transmission engine had a slightly bigger cam. I was pretty sure my 1969 340 had the shield on the LH manifold. I think I tossed it when I rebuilt the engine. Probably a bad move looking at what MP wants for a new one.
Floyd Lippencott IV
Re: What are the differences between 68 and 69 340's [Re: mr_340] #469609
09/16/09 12:42 AM
09/16/09 12:42 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Dingmaster, be careful using those old B&W factory photos as a 100% accurate references, it's possible that it/they could be of a prototype/pre-production car that was used for promo shots.
Re: What are the differences between 68 and 69 340's [Re: Dingmaster] #469610
09/16/09 10:32 AM
09/16/09 10:32 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Bill,
If you look closely at the heat shield on the picture above you can see the difference. 1968's have a gap between the shield butterfly portion of the shield. as opposed to the 69-72 shield (pic is attached ) the 2 pieces are longer and thus joined in the center
