Indy 360 CNC head users, how are you making compression #469561
09/15/09 09:36 PM
09/15/09 09:36 PM
Maryland
340_Dart Offline OP
340_Dart  Offline OP
Maryland
I posted the 408 motor combination in my 68 valiant race car here last week and through the responses i got, it seems i need to increase compression from 10.8 to 12.5 or 13.1 to reach my goal of 10.00's
The issue i'm having with doing this is how can i get that compression considering the relatively large chamber of the CNC indy head (68-70 cc) My current 408 combo has diamond flat top pistons, set .005 below deck.
I talked to RyanJ about increasing compression, and he suggested we mill the heads down to the intake valve seats, making them 59-60cc's. That will increase compression to 12.3 by my calculations. I guess you could call me a conservative, but i'm worried about doing that since the heads will never be able to be cut again.
How are other 360 head users making this kind of compression? Custom domes? thanks-Andy
Re: Indy 360 CNC head users, how are you making compression [Re: 340_Dart] #469562
09/15/09 09:59 PM
09/15/09 09:59 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Take most of it off the head and get the rest with a little dome.
Here's a 6.8 cc, zero effective volume dome for an Edelbrock head.
Re: Indy 360 CNC head users, how are you making compression [Re: S/ST 3040] #469563
09/15/09 10:05 PM
09/15/09 10:05 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Cut them, not sure about a smallblock but on a big block it also helps to un-shroud the valves and will help flow.
Re: Indy 360 CNC head users, how are you making compression [Re: 340_Dart] #469564
09/15/09 10:28 PM
09/15/09 10:28 PM
we have pistons specific to the Indy heads to get your compression up without cutting the daylights out of your heads. that's the easiest way to get where you want to be.
Re: Indy 360 CNC head users, how are you making compression #469565
09/16/09 12:19 PM
09/16/09 12:19 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
what comp do you get in a 410 and price and do they come with chev pins thanks
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Indy 360 CNC head users, how are you making compression #469566
09/16/09 12:43 PM
09/16/09 12:43 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
This what I did. Ordered some pistons from Dram that fill up the chamber. Yes they have the .927 pin in them. Should have it running Thursday.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Indy 360 CNC head users, how are you making compression [Re: Jacob Pitt] #469567
09/16/09 01:06 PM
09/16/09 01:06 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
I typed out a long winded reply to several of these responses, & then realized all I was going to do was piss off everyone, so I'll bite my tongue & say "no comment"
You know my thoughts on what would be the "easiest way" so.... no sense in beating a dead horse.
Re: Indy 360 CNC head users, how are you making compression [Re: RyanJ] #469568
09/16/09 01:53 PM
09/16/09 01:53 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
If more compression is your aim, and doing it affordably is much of a factor, then i would mill the heads. I did exactly that on my eddie heads a few years ago to up my compression about the amount you are wanting to do on my old 416 motor.They were flattops 5 in the hole.
The fact is, if you cut them and even decide down the road to build a different motor using those same heads, just spec the NEW pistons to where the new milled heads would be chamber wise..
Otherwise you have new pistons, rings, balancing, etc, involved in just wanting to raise your compression..and most likely everything else, mains, rods, etc if you have it completely pulled apart anyhow.
Milling the heads just involves head gaskets/intake gaskets and an afternoon in the garage.......and will net the desired result.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Indy 360 CNC head users, how are you making compression [Re: B3422W5] #469569
09/16/09 06:25 PM
09/16/09 06:25 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
my chambers came from Indy at 74cc so I used a dome
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Indy 360 CNC head users, how are you making compression [Re: B3422W5] #469570
09/16/09 07:04 PM
09/16/09 07:04 PM
lino lakes,MN
onebaddakota Offline
lino lakes,MN
True, but at some point you have to worry about intake alignment issues and pushrod lengths.
Tom
10.56 at 125.6, with a 1.43 60 ft. E85, Hyd. Roller 410 magnum,full exhaust, 3500 race weight.
Re: Indy 360 CNC head users, how are you making compression [Re: 340_Dart] #469571
09/16/09 09:59 PM
09/16/09 09:59 PM
there's no doubt that milling the heads is the "cheapest" way, for the time being at least. one of the problems is it doesn't really get you where you want to be on C/R. the other is that your basically to the limit of how much you can mill that head. what happens in the future not if, but when they need to be touched up again? another thing that happens is you affect the amount of valve to piston clearance by milling that much off any head, especially the Indy head though because of the valve/ seat placement in the chamber. you'll also be milling a ton either off the intake side of the head or the intake itself. that can be problematic to take that much off the intake side of the head since that area is already thin. sealing, or even fitting the valve cover can become a problem. as far as i know, everyone that we've done pistons for here on Moparts has been very pleased with what we've done, and that's a lot of people.
Re: Indy 360 CNC head users, how are you making compression #469572
09/17/09 12:11 PM
09/17/09 12:11 PM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
My major concern with milling would be the valve to piston clearance. I have a Batten w-2 right now that had a new seat put in on an intake valve and it's going back to be sunk for that very reason. But if your getting pistons a special deep pocket could be specified. The ones I'm dealing with are .280 deep from plane.
