Annual cost difference of 10.00 vs. 9.99? #469340
09/15/09 07:22 PM
09/15/09 07:22 PM
Huron, South Dakota, United St...
dustyhof Offline OP
dustyhof  Offline OP
Just wondering if anybody has actually figured out a dollar amount annually for going quicker than a 9.99? Licensing, physicals, chassis cert., expiring SFI equipment, safety clothing, etc. Inquiring minds want to know.
Re: Annual cost difference of 10.00 vs. 9.99? [Re: dustyhof] #469341
09/15/09 07:26 PM
09/15/09 07:26 PM
Renton Washington
Triple Threat Offline
Renton Washington
Too much, If you're gonna run in that area go 10.00 If you want to run 9's and deal with all the crap, run deep into the 9's.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Annual cost difference of 10.00 vs. 9.99? [Re: Triple Threat] #469342
09/15/09 07:30 PM
09/15/09 07:30 PM
I did it about 10 years ago, it was about $50 a month. I went IHRA racing instead and used the money for entry fees.
Re: Annual cost difference of 10.00 vs. 9.99? [Re: ] #469343
09/15/09 07:44 PM
09/15/09 07:44 PM
dustyhof Offline OP
dustyhof  Offline OP
So about $600.00 a year?
Re: Annual cost difference of 10.00 vs. 9.99? [Re: dustyhof] #469344
09/15/09 07:56 PM
09/15/09 07:56 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
NHRA cage certification.....$230.....NHRA phys with EKG.......$500....being able to run in the 9's....ah well...take your clothes off, take down that net...run 10.00....PRICELESS! Said this B4, but don't do it. Fun=expensive
The little old lady from Pasadena is back!
Re: Annual cost difference of 10.00 vs. 9.99? [Re: Barnstorm] #469345
09/16/09 12:01 PM
09/16/09 12:01 PM
NW PA
V10nacuda Offline
V10nacuda  Offline
NW PA
Cage cert $230???????????
$75.00 & the fellow came to me..........
V10
Re: Annual cost difference of 10.00 vs. 9.99? [Re: V10nacuda] #469346
09/16/09 12:27 PM
09/16/09 12:27 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Yep...Div 5 [and I'm assuming all of NHRA] doubled the fee early this year. He's a friend that done the car for 10 years, lives 2 mi away and drank my beer! It was $110 in 2000.
Re: Annual cost difference of 10.00 vs. 9.99? [Re: Barnstorm] #469347
09/16/09 12:36 PM
09/16/09 12:36 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
It is a lot I know that, because you won't stop at 9.99 that's for sure
Re: Annual cost difference of 10.00 vs. 9.99? [Re: MegaDart] #469348
09/16/09 01:01 PM
09/16/09 01:01 PM
PA
moparacer Offline
moparacer  Offline
PA
Glad someone posted this question as I am in the same predicament right now.
Labor day weekend I had to add 65 Lbs to the car to keep it out of the 9's at 2200ft DA.
I already have it slowed down with a loose converter and gear and when the weather really comes around in October I will end up with a couple hundred pounds in the car keeping it 10.00....
Really on the fence as to which way to go....
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Annual cost difference of 10.00 vs. 9.99? [Re: moparacer] #469349
09/16/09 01:18 PM
09/16/09 01:18 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
If oyu are going to run 9's and incure the expenses that go with it I suggest making the car capable of running well into the 9's. Hardley worht the money and time to have a car running 9.90's in good conditions to put up with all the added costs. If I had a car that was running right at the number I woudl find a way to maek it run 10.0's for sure, with the occasional 9 second blast maybe..
Re: Annual cost difference of 10.00 vs. 9.99? [Re: Al_Alguire] #469350
09/16/09 02:50 PM
09/16/09 02:50 PM
Peoples republic of clackamas ...
atoetly Offline
atoetly  Offline
Like already said not worth the price unless your going to run mid 9's Even then with a car that is capable of running low tens you better watch that 1/8th mile et as well. my dart would run ten teens and be in the 6.30's in the 1/8th 6.39 1/8th = 9.99 1/4
Re: Annual cost difference of 10.00 vs. 9.99? [Re: Al_Alguire] #469351
09/16/09 03:01 PM
09/16/09 03:01 PM
Port Orchard, Washington
Bad Boy Offline
Bad Boy  Offline
I have not figured it out for an annual amount but I did for the first year layout. I just did this this year. The total cost for all of the safety equipment, the chassis cert, and the physical was $2065.83. Your cost may vary depending on what's already in your car and how old you are. The physical requires an eye exam and an EKG if you are over 50. There are also lab fees for blood tests etc. The Chassis cert went up to $200.00 this year . The license fee went up to $100.00 this year. And because everything for a MOPAR costs more the trans shields and flex plate shields are more expensive. Going 10.0 is not any cheaper if you exceed 135mph. You have to meet the 9.99 or quicker requirement at 135. So build to go 10.0 at 134 and you don't have to spend the money or do the paperwork every 2 to 3 years.
Re: Annual cost difference of 10.00 vs. 9.99? [Re: Bad Boy] #469352
09/16/09 03:35 PM
09/16/09 03:35 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Its a real pain to go fast these days, I'm all for sit safety, but on those hot days, boys is it a pain. You wont see me @ the track if its over 90, to sit in the pits all strapped up,( once they call your lane) and if then someone breaks down, you get the picture. The price to go fast just $$$, its so aggravating
Re: Annual cost difference of 10.00 vs. 9.99? [Re: atoetly] #469353
09/16/09 05:39 PM
09/16/09 05:39 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
yep your 1/8 mile et's will get you busted long before you hit the 9's in the quarter unless you are running a turbo or something that makes the car a turd outta the hole.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Annual cost difference of 10.00 vs. 9.99? [Re: Irun5snd8th] #469354
09/16/09 09:14 PM
09/16/09 09:14 PM
Ohio
Lil Wedge Offline
Lil Wedge  Offline
Ohio
Yea, this weekend we went from 1/4 mile on Saturday to 1/8 mile on Sunday at our track, And I went to the tower and showed time slips for 10.02-10.05 with 1/8 mile in the 6.27- 6.29 range and told them it would be hard to comply with the 6.40 rule and they said no problem, so we got to run . That 6.40-10.00 thing must be based on Powerglides.
Re: Annual cost difference of 10.00 vs. 9.99? [Re: Lil Wedge] #469355
09/17/09 01:00 AM
09/17/09 01:00 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
A 6.27 should put you solidily in the 9.80's. Sounds like either you run a stocker or you need to find out what is going on at the top end of the track with your engine...
