Rear-end fluid change #469111
09/15/09 02:40 PM
09/15/09 02:40 PM
Central, Indiana
mc4406 Offline OP
mc4406  Offline OP
Central, Indiana
With todays technology whats the best gear oil to run in a 8-3/4 rear with 3.91 ratio for best protection.
Re: Rear-end fluid change [Re: mc4406] #469112
09/15/09 03:11 PM
09/15/09 03:11 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
What kind of use? What's it in?
- Stu Harmon
Re: Rear-end fluid change [Re: feets] #469113
09/15/09 03:17 PM
09/15/09 03:17 PM
Arkansas
K
kzcountry Offline
kzcountry  Offline
K
Arkansas
I used 75W-140 Mobile 1. I just changed out a couple of chuncks and called Dr. Diff. He reccommended 75 or 85 - 140 and Make sure the gear lube is GL-5 rated.
