Re: leaking headers 440 HELP!
[Re: jbcuda]
#468817
09/15/09 11:22 AM
09/15/09 11:22 AM
Posts: 1,249 Las Vegas
JeffC
Las Vegas
440 cuda with hooker header i have changed gaskets twice and used several different thread sealers and cant stop coolant leaks. any suggestions?
Do you have an exhaust leak and a coolant leak, or just a coolant from the header bolts?
To seal the header bolts I like teflon tape.
With hooker and headman headers I have had to run two sets of felpro header gaskets to get them to seal.
[Re: jbcuda]
#468820
09/15/09 11:48 AM
09/15/09 11:48 AM
Posts: 543 Indiana, Just Off I-70
BradD
Use RTV for high heat apps.! Give it time to set up before adding coolant. I can sell you gaskets that wont leak! PM me. Brad Dorn Autocraft
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
[Re: BradD]
#468821
09/15/09 10:10 PM
09/15/09 10:10 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Teflon may work. I've read about it here more than once but it's not what it's made for. Teflon is for lubrication pipe thread.
Header bolts are going to be a bit of a challenge to seal. Straight threads were never designed to seal anything.
The ultimate answer is exhaust studs. They have a shoulder in between the 2 threads that you bottom out and creates a seal. For extra insurance. I'd still smear high temp rtv silicone on the threads.
No garantees with rtv silicone on header bolts but it's worked for me 95% of the time and that last %5, just redo it. It'll seal
