Re: off-set roller lifter ?
[Re: mac56]
#468208
09/14/09 10:49 PM
09/14/09 10:49 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
For those of you that use them or have used them is there any negative effect to running them. I would think that the off-set cup would side load the tie bar causing wear on the bars or wheel from the load not being centered which would make the lifter try to turn away from the load. Thanks
With our lifters, you get oiled bearings via EDM hole which greatly reduces wear from slight side loading. I've used them in blown engines, NOS, NA and no problems. Here's a pic of one...
[Re: Brian Hafliger]
#468209
09/14/09 11:49 PM
09/14/09 11:49 PM
Posts: 903 Saskatchewan, Canada
cudabin
Brian, With the side mounted oil holes parrelel to the axle, do you recommend a restriction in the pushrods when pushrod oiling on an indy Maxx block? These lifters worked great in my unbuhed 400 stock block as is !!! ![](/ubbthreads/images/graemlins/thumbs.gif) Cheers, Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
#468211
09/15/09 12:59 AM
09/15/09 12:59 AM
Posts: 6,150 Melbourne , Australia
LA360
Comp Cams makes an offset Key way lifter. Darren Tedder deals in a lifter brand comparable to Jesel stuff at half the price. I forget his user name, sorry. AL....
Alan Jones
#468212
09/15/09 12:27 PM
09/15/09 12:27 PM
Posts: 976 ontario canada
mac56
ontario canada
Brian do you recommend bushed lifter bores for your lifers? I see cudabin wrote he used them unbushed without issue.
[Re: mac56]
#468213
09/15/09 01:07 PM
09/15/09 01:07 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
They are meant to work very well with no bushings! Alot depends on how much lobe lift you run, but you can always have the base circle reduced on the cam when you order it to drop the lifter down some. You should have no problems up to a .450-.460 lobe. I've run .470 lobes with no issues, just needs checking to make sure the oil galley is not uncovered.
Brian Hafliger
[Re: LA360]
#468214
09/15/09 01:10 PM
09/15/09 01:10 PM
Posts: 705 Michigan
Hemiroid
DTHemi, and he's a cool dude ![](/ubbthreads/images/graemlins/thumbs.gif)
#468216
09/15/09 07:39 PM
09/15/09 07:39 PM
mac56
ontario canada
I won't be running any more lift than that.
