Wedge or Hemi #467675
09/14/09 05:56 AM
09/14/09 05:56 AM
Stockholm, Sweden
MrSixpack Offline OP
Stockholm, Sweden
My friend wants me to help him building a 1000hp streetīn strip engine.
No problem for me.
He tells me money is no problem, but I know he does not know what a good engine will cost.
So he rings me last nigh telling me is on the net getting ready to order a block, I told him wait and let me check things out first.
So we are going to use a iron block, the key to the build is low maintenance.
He is not a engine guy and I can not help him all the time.
So a big cube wedge or hemi, but what is the best bang for the bucks. I think a 550 somthing with the big indy heads, so what do you think
1970 Super Stock Challenger ex. Paul Rossi
1968 Dodge Dart GT 340
1968 Dodge Charger /6 3 speed manual
1966 Chrysler 300 Loaded
1968 Dodge Charger R/T 440
1968 Mini Cooper
Re: Wedge or Hemi [Re: MrSixpack] #467676
09/14/09 06:11 AM
09/14/09 06:11 AM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
How much you got ????
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Wedge or Hemi [Re: MrSixpack] #467677
09/14/09 06:16 AM
09/14/09 06:16 AM
Q
Quicktree Offline
Quicktree  Offline
Q
better be planning on a turbo or pro charger. 1000 in street trim will be very hard.
Re: Wedge or Hemi [Re: MrSixpack] #467678
09/14/09 06:23 AM
09/14/09 06:23 AM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
No problem for me.
He tells me money is no problem, so what do you think
Call Roy Johnson and have him build you a 605
Hemi or Wedge, what ever you want. On pump gas
he will make over 1000 HP easy.
Larry Morgan might have some good deals on Hemi
stuff at the end of the season.
Money is no problem? Right!
Snap your neck, mega G-force launch, is all I want!
Re: Wedge or Hemi [Re: BDS871Cuda] #467679
09/14/09 07:18 AM
09/14/09 07:18 AM
Netherlands
72Challenger Offline
Netherlands
bang for the buck...
cast iron wedge 4.5" bore
stroker kit (you want it all forged anyway)
indy sr heads or something like that
hydraulic roller cam for the low maint
procharger
Sound slike a low maintenance, cheaper then a hemi, torque hp monster. But the engine guys will have more and properbly better options I guess.
Re: Wedge or Hemi [Re: MrSixpack] #467680
09/14/09 07:30 AM
09/14/09 07:30 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
572ci or more. but as the other guys said, 1000hp n/a is quite difficult especially when you throw in low maint. he'll be changing valve springs alot.
n/a you'll need heads that flow over 450cfm. so you're looking at ported B1's, ported Pred, ported Hemi, or Hemi 99
Re: Wedge or Hemi [Re: Defbob] #467681
09/14/09 08:18 AM
09/14/09 08:18 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
He's not asking for much is he?
Tim at FHO built me a pump gas procharged 547" hemi.
It made 1066hp 14 pounds of boost.
He just built a 604" hemi that made 1100 hp. 14:1 mopar cross ram intake.
It will be more difficult to do in a wedge then a hemi.
Re: Wedge or Hemi [Re: The Shadow] #467682
09/14/09 08:34 AM
09/14/09 08:34 AM
Stockholm, Sweden
Stockholm, Sweden
I think this is all good, now I can show him what you say and write, even if I tell him the same thing he must have a second opinion
Just becouse I built my latest SixPack engine and it made just under 700 hp in Super Stock mode he thinks it's easy to just go a little bigger and get 1000hp.
He has no clue in what it thakes to make my 440 to live at 700hp.
I will now tell him he need at least $40-50.000 to get a 600cui monster that makes 1000hp easy and are reliable on the street.
1968 Mini Cooper
Re: Wedge or Hemi [Re: MrSixpack] #467683
09/14/09 08:54 AM
09/14/09 08:54 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
There are a number of ways to do this.
Ask him what he like to look at....Screw, roots, oxide, turbo, procharger, big cube N/A, etc.
Let him narrow it down, then come back for specifics.
Re: Wedge or Hemi [Re: MrSixpack] #467684
09/14/09 12:13 PM
09/14/09 12:13 PM
I have made more HP and torque building wedge motors than with Hemi motors My choice would be a max ported set of B1 and a World block with either 4.5 bore and 4.5 stroke or 4.625 stroke, pump gas and a 150 or 200 HP NOS set up
Re: Wedge or Hemi [Re: Cab_Burge] #467685
09/14/09 05:34 PM
09/14/09 05:34 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I would call best machine and go for a set of the Predator heads on a 572 or bigger with the cast single 4 barrel intake and a dominator. It might not make the full 1000hp, but it should be over 900hp and very reliable.
Post deleted by Defbob [Re: Dragula] #467686
09/14/09 05:51 PM
09/14/09 05:51 PM
Re: Wedge or Hemi #467687
09/14/09 06:35 PM
09/14/09 06:35 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
Big cubes Fully ported B1-Mc engine
Re: Wedge or Hemi #467688
09/14/09 07:15 PM
09/14/09 07:15 PM
Hemiroid Offline
Hemiroid  Offline
forced induction pump gas hemi
Yep, not gonna see 1000 streetable horsepower from a n/a motor.
And if you're going to blow something, it might as well be the engine that responds best to it.
Re: Wedge or Hemi [Re: Hemiroid] #467689
09/14/09 07:54 PM
09/14/09 07:54 PM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
Big (500+) twin turbo Hemi ought to be easy enough.
My buddy with the Chevy 502 (502 crate motor) twin turbo Ford Ranger made 1000+ to the wheels with this combo.
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: Wedge or Hemi [Re: Hemiroid] #467690
09/14/09 08:02 PM
09/14/09 08:02 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
pump gas Predator head on a Hemi block will make 1000+ N/A
Post deleted by Defbob [Re: Sledge_57] #467691
09/14/09 08:09 PM
09/14/09 08:09 PM
Re: Wedge or Hemi [Re: TS3303] #467692
09/14/09 08:11 PM
09/14/09 08:11 PM
Hemiroid Offline
Hemiroid  Offline
Yes it will. But because it runs on pump gas doesn't necessarily make it street able. If by street able you mean it will survive the NMCA 30 mile run, ok. Not sure I'd really consider a predator engine that's 600" with a huge roller street able but that's just me. Your mileage may vary
Re: Wedge or Hemi [Re: Sledge_57] #467693
09/14/09 08:12 PM
09/14/09 08:12 PM
Hemiroid Offline
Hemiroid  Offline
I saw that at the last heads-up race at Milan I believe. Pretty wild!
Re: Wedge or Hemi #467694
09/14/09 08:14 PM
09/14/09 08:14 PM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
big deal 2000 at crank with 450 Hemi and only 28lb boost
web page
He's looking for streetable Fred, this truck gets driven 500 miles a week on the street.
I'm guessing yours will never have 500 miles total on it
Doug
