Pertronix conversion vs Electronic ignition
#467503
09/13/09 11:14 PM
09/13/09 11:14 PM
Posts: 1,169 clarks summit pa
73cuda340
clarks summit pa
What do you guys prefer to run; points converted with the pertronix kits or the mopar performance electronic ignitions? any experiences with which is better?
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: Pertronix conversion vs Electronic ignition
[Re: Paul_Fancsali]
#467506
09/14/09 05:59 PM
09/14/09 05:59 PM
Posts: 3,310 Walnut Creek, CA
blown340
Walnut Creek, CA
I have the pertronix on all of my cars which used to have points and it has worked excellently for me. I think the one in my valiant must be almost 15 years old now and still works great.
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
[Re: PASTLITE]
#467508
09/14/09 06:58 PM
09/14/09 06:58 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Pertronix converted distributors, the only way to go, the Factory or MP electronic ignition is just frought with to many componets, destined to fail, the Pertronix if installed correctly with the required componets, is very reliable, and trouble free, the car starts better, runs better, the cap stays clean, no carbon tracking, no pitting/burning on the rotor, and the benefit of getting rid of the ballast resistor is another plus,....until something else comes along better, the Pertronix is all I'll run,......got tired of "foolin" with all the other crap over the years Mike
[Re: Dakota_Don]
#467512
09/15/09 07:54 PM
09/15/09 07:54 PM
Posts: 18,157 Mass
DAYCLONA
Mass
anyone use the pertronix II? how did you lke it?
I should have clarified in my earlier post, Pertronix Ignitor II systems are what I run in my stuff,.....Have no interest in going to the Pertronix III billet distributors, but the guys I know running them, love'em
Mike
[Re: Mopar1970440]
#467517
09/16/09 01:08 PM
09/16/09 01:08 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
Had Pertronix conversion kit on my car for several years...had several coils go out. Switched to mopar elect ignition for last few years..no problems! Just chance or what? i dont know..but it has me thinking that the petronix was possible killing coils maybe?
What brand of coil? How much voltage did you have at the coils? Did you bypass the ballast resistor?
The ignitor I, II, and III require a certain voltage at the coil. I'll admit I burned up a Pertronix coil, but it was my fault for not doing a loaded voltage test.
[Re: 73cuda340]
#467519
09/16/09 03:35 PM
09/16/09 03:35 PM
Posts: 108 st.charles,mo.
dodgem1
st.charles,mo.
i use a 35.00 rebuilt dis from oreillys,vac-adv removed hooked to a 6al,you just unhook the condenser,throw it out and run the wire from the points to the 6al,the points no longer have fire they are only a trigger devise,it works great,its the first diagram in the 6al manual,now you have a 1 wire dissy,the guy in texas at msd,says its a great way to runem,my
