Question for nitrous guys? #467348
09/13/09 10:04 PM
09/13/09 10:04 PM
Gainesville, Fl
lildevil1972 Offline OP
Gainesville, Fl
Hey all u nitrous users. I have a question about nitrous, I have never used nitrous and i would like to put it on my engine and i am wondering what u think? I am wondering if my engine will handle it. I have a stock block 512 low deck with a 440 source rotating assembly and bcr aluminum main caps with arp studs, Edelbrock ported max wedge heads with arp studs and cometic head gaskets and a 1050 dominator with an indy intake. It is 10.7 to 1 compression and made 703 horse on the engine dyno. It's in a 1972 dodge demon, it's a street/strip car it has lots of power but i want to put on a plate system with like a 150 shot. I wouldn't use the nitrous much maybe a dozen times a year i don't plan on getting my nhra license and with this setup without nitrous should get close to 9's I need input on this if it would be reliable and tips on sucessful nitrous use. any input would be appreciated thanks.
Re: Question for nitrous guys? [Re: lildevil1972] #467349
09/13/09 10:05 PM
09/13/09 10:05 PM
Gainesville, Fl
Gainesville, Fl
Oh and the block is a 230 casting 400 block with a half fill of hard block.
Re: Question for nitrous guys? [Re: lildevil1972] #467350
09/13/09 10:30 PM
09/13/09 10:30 PM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
That stroke is hard on the block.I like to keep the stoke about 3.9,but i think you will be fine.If you only spray it a couple times a year, it will be cool.The 9s should not be a problem.It suould run it the 8s.Lenny
Re: Question for nitrous guys? [Re: 8secDart] #467351
09/13/09 11:34 PM
09/13/09 11:34 PM
Eagleville Tn.
rtstreet Offline
rtstreet  Offline
Eagleville Tn.
spray it!!!!
Re: Question for nitrous guys? [Re: rtstreet] #467352
09/14/09 12:41 AM
09/14/09 12:41 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
the most important thing with your type of combo ia to maKE sure you keep the engine out of detonation. Use a good fuel even C16 and make sure you retard the timing a decent amount
....BAD A$$ STREET CAR.....
