K member swap Wanna check my knowledge #467338
09/13/09 09:59 PM
09/13/09 09:59 PM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
Met a guy today who has a 72 Coronet Wagon with a 400. He got the car because he was told he could take the K member with the disc brakes and swap them into his 71 E body which currently has a 318.
Im gonna say this isnt gonna work,as the donor car is a B Body and the car he wants to put the stuff in is an E body.
I want to break the news to him(if I am actually correct) but I also would like to help him out as in what he can do as far as swapping a big block into his Challenger.
Re: K member swap Wanna check my knowledge [Re: SPWC] #467339
09/13/09 10:05 PM
09/13/09 10:05 PM
AndyF Offline
AndyF  Offline
It will all bolt in just fine but the steering box angle was different for some E body cars. I'm not sure which years are different so that is one thing to check on.
The other issue is that the '72 disc brakes aren't that great of a setup. The 1973 or newer A body disc brakes are better.
Re: K member swap Wanna check my knowledge [Re: AndyF] #467340
09/13/09 10:14 PM
09/13/09 10:14 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
'71-'72 B-body K-member and brakes interchange with the E-body stuff.
The steering box angle is different on pre '71 B-bodies.
Re: K member swap Wanna check my knowledge [Re: DoctorDiff] #467341
09/13/09 11:45 PM
09/13/09 11:45 PM
SPWC Offline OP
SPWC  Offline OP
Ok well there ya go.. I was almost certain that this swap wouldnt work. I wanted to give the guy the news IF it wouldnt have worked,because I didnt want the guy to do all the work and then find out it wouldnt fit.That would have been a bummer. Thanks for the education
