spark plugs for my 440 #467170
09/13/09 07:15 PM
09/13/09 07:15 PM
Anonymous OP
Anonymous OP
I am going to replace the old spark plugs in my 440, (stock engine) the parts house looked up my application and gave me champion RJ12YC, the ones that were in it were RJ18YC, is there that much of a difference between the two, it is my understanding that with champion plugs the higher the number the "hotter" the plug, should i go ahead with the colder one?
Re: spark plugs for my 440 #467171
09/13/09 07:30 PM
09/13/09 07:30 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I think they gave you the right plugs, 18 is a awfully hot plug.
Re: spark plugs for my 440 #467172
09/13/09 07:31 PM
09/13/09 07:31 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
leave the champion plugs for your lawn mower. Autolite number 85
Re: spark plugs for my 440 [Re: Dougsmopars] #467173
09/13/09 09:54 PM
09/13/09 09:54 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
autolites are for fords RJ12YC is it man!!
Re: spark plugs for my 440 [Re: Dodgem] #467174
09/13/09 10:01 PM
09/13/09 10:01 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Champions are for lawn movers. I've had better luck with autolites in my mopar than the champs for sure.
Re: spark plugs for my 440 [Re: DaytonaTurbo] #467175
09/13/09 10:04 PM
09/13/09 10:04 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
NGK's work great in mine.
Re: spark plugs for my 440 [Re: DennisH ] #467176
09/14/09 11:26 AM
09/14/09 11:26 AM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
NGK XR5's.
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
Re: spark plugs for my 440 [Re: Viol8r] #467177
09/14/09 12:34 PM
09/14/09 12:34 PM
Central IL
70Sbird Offline
70Sbird  Offline
Central IL
Another vote for Autolite 85's
I've used the Champions too with no problems, But stay away from Bosch Platnium in this application
Re: spark plugs for my 440 [Re: 70Sbird] #467178
09/14/09 12:58 PM
09/14/09 12:58 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
If I have a choice I won't but jap crap in mine!
One summer my machinist talked me into trying other brands. It took him years as I was champs or nothing!! Being a ford guy he was big on autolites.
so we tried autolites first they were OK ran same times. then NKG they were OK ran same times but if you cold fouled them they stayed fouled. Then we got AC's they were OK ran same times but same as NKG on the fouling. we tried Accel they were OK ran same times and same as the preceding two if you fouled them they needed to be manually cleaned. Then we tried bosch platnuim they worked good but no better than a Champion so not worth the cost most of these plugs were given to us as people heard we were doing testing and were sure what they were using were the best. Car ran 12.0's nibbling on some high elevens at the time and was street driven. all plugs got at least two weeks of street driving and strip runs as we were racing every week end.
Now my machinist tells people the story saying in the end Barry was right overall the champions work best. That's probably the only thing we don't argue about and I never hear of it any more!!
Mopar says use Champion, Indy says use Champion and Edelbrock says use Champion and these guys should have an idea what works best with their products!!!!
This week end I had my plugs way cold fouled from hours of garage idling chasing and oil leak. they were cleaned up before the first burn out was done and ran flawless all day sunday!!!!!
C59CX if I had iron heads they would be RJ12YC's
PS I tell the chevy boys to stick with AC's and Ford boys to stick with Autolites and I just don't talk to the Jap scrap types!
Re: spark plugs for my 440 [Re: Dodgem] #467179
09/14/09 01:49 PM
09/14/09 01:49 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
champions are made in mexico and autolites in china
Re: spark plugs for my 440 [Re: 05dakota] #467180
09/14/09 02:02 PM
09/14/09 02:02 PM
Anonymous OP
Anonymous OP
Most plugs are not very good. We raced a 13:1 max wedge car. Before we put any plug in it, we checked them with an old champion plug tester. AC, Autolite, Champion, and Prestolite all tested about the same. From 75 PSI to 130 PSI. We used only the ones that checked 120 or above. The car ran about .3 seconds faster with checked plugs. Later i ran a blown alc 517 hemi. Used 60 series (race) Champion plugs. Did not need to check them.
Re: spark plugs for my 440 [Re: 05dakota] #467181
09/14/09 02:11 PM
09/14/09 02:11 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I see my new ones are Mexican still better than China and Japan. besides I'm doing my part to keep the Illegal's in Mexico!!! You American's should thank me although they have discovered our boarders now too??
Re: spark plugs for my 440 #467182
09/14/09 02:17 PM
09/14/09 02:17 PM
Anonymous OP
Anonymous OP
The 517 hemi we raced was in a monster truck (Dodge of course). Had be running it for a while and got feeling guilty about not changing the plugs so got a set of standard duty plugs. Changed them between rounds at a race in New York. It started and idled fine, but when i hit the throttle on the starting like the engine went to about 3000 RPM and then sounded like it hit a rev limiter. Went back to the pits, put the Champions (60 series) back in and it ran fine. Went from the Champions to NGK's and they worked just like the Champion race plugs. If you don't use race or tested plugs, good luck.
Re: spark plugs for my 440 #467183
09/14/09 02:38 PM
09/14/09 02:38 PM
Anonymous OP
Anonymous OP
Re: spark plugs for my 440 #467184
09/14/09 04:03 PM
09/14/09 04:03 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I like it!!!
Re: spark plugs for my 440 #467185
09/14/09 04:28 PM
09/14/09 04:28 PM
Cincinnati, Ohio
Cincinnati, Ohio
Very cool truck!!!
I have used Champs for years instreet cars and trucks, but I realize they may have changed in the last few years.
Now in my TAD 451" PSI blown hemi, it will consume 8 NGK plugs per 1/4 mile. It used to be 16 per run. I wouldn't think of putting anything else in there.
Re: spark plugs for my 440 [Re: Challenger 1] #467186
09/14/09 04:59 PM
09/14/09 04:59 PM
Dougsmopars Offline
Dougsmopars  Offline
I had champs in my motors when i was a kid. They never lasted more then a few hundred miles. My 12.5 to 1 motor used to burn the electrodes right off them within a 100 miles. I've been using 85 autolites for over 30 years never had a problem. My local speed shop has been using them in his 440 powered 63 Dart for 35 years. Car runs 10.0 like clock work. I'll stick with whats been working for me for many years. And skip the Mexico and jap crap. This is America, the only thing we make here is bad politicians.
Re: spark plugs for my 440 [Re: Dougsmopars] #467187
09/14/09 05:36 PM
09/14/09 05:36 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
you must of had the wrong heat range for the champs. if you bye china made autolites how is that better than Jap or Mexico??
Re: spark plugs for my 440 [Re: Dodgem] #467188
09/14/09 06:16 PM
09/14/09 06:16 PM
Dougsmopars Offline
Dougsmopars  Offline
Had the correcdt heat range. Champion plugs suck in plain english. And don't kid your self them junk champion's aren't made in the US either. And if you hate parts made out side the US so much you better get rid of your Mopar. 99% of all the aftermarket and even name brand stuff is not made here. Even MSD is made outside the US.
Re: spark plugs for my 440 [Re: Dougsmopars] #467189
09/14/09 06:58 PM
09/14/09 06:58 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Any Champion plug that makes it into my garage gets the hammer.
Many years ago I've wasted almost an entire year trying to get a 361 BB to idle or let alone started after I had put in a set of correct range Champion-plugs.
In that year I replaced almost everything on top end on that engine. Never could get to start and stay running properly. Then one day, out of the blue, I just put in the original set of used plugs consisting of 3 different brands which I still had kept, the motor fired up on the first turn.
Tried the Champions again, to no avail. Even bought another set thinking they might be defective by now from all the starting and such, they didn't work either.
From then on I hate Champion sparkplugs.
A local garage provides me with Accel-plugs.
"Accel 134" for bigblock Mopar motors. Got them in all my cars and never had one fail since years now.
I put them in and forget about them. With some of my cars I can't even remember when I did put the plugs in anymore, they seem to last forever.
