Re: this thing should mph better? [Re: dart443] #466809
09/13/09 12:32 PM
09/13/09 12:32 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Which model of Mighty Demon 850 (downleg or annular boosters)? Has it been tuned at all, or is it "out of the box"?
When you say the heads have been ported, are they still the standard runner size or did they get opened up to MW size?
And maybe I missed it, but what type & size headers do you have?
What RPM are you turning going through the traps?
Re: this thing should mph better? [Re: BradH] #466810
09/13/09 12:44 PM
09/13/09 12:44 PM
ontario canada
dart443 Offline OP
dart443  Offline OP
ontario canada
annular boosters 80 90 jets stock air bleeds,ported to max wedge,tti 2 inch
Re: this thing should mph better? [Re: dart443] #466811
09/13/09 01:21 PM
09/13/09 01:21 PM
Cab_Burge Online work
Cab_Burge  Online Work
I think the Holley blue pump is the problem Been there done that Put a 250 or bigger pump on it My Duster with a set of Eddy RPM standard port heads(518C.I., 10.29to1 comp ratio) and a bigger cam with similar weight(3430 with me in it) runs 10:40 at 128.+ MPH with a 10 inch converter and 3:73 gears with 315x60x15 ET Street Rdials I had a Magnafuel 275 pump on it and I could not jet the carbs up enough to slow the car down, I switch to a Magnafuel 300 pump and it slowed down and made the AFR go rich with the same jetting that the car ran 128.+ mph this is a street & strip car ran with the exhaust on, air cleaner on and on pump gas
Re: this thing should mph better? [Re: Cab_Burge] #466812
09/13/09 02:19 PM
09/13/09 02:19 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I'm almost think it is fuel too! he left at low RPM first pass bogged 1.57 short and with a 11.3 went 120 then next run he does not bog went 1.47 short and 11.26 @ 119??? When I have a bad 60 the pick up a 1/10th in the 60 next round I usually gain .2 quarter and a mph or two??
It's almost like the better he launches the less it pulls??
Re: this thing should mph better? [Re: Dodgem] #466813
09/13/09 03:26 PM
09/13/09 03:26 PM
Netherlands
72Challenger Offline
Netherlands
I would guess it would pick up ET when you get bigger in the fuel pump, carb and convertor department. Your 60ft tells to run high 10's so for your launch the convertor can't be bad but the cam would like you to be sooner at higher rpms I guess.
So basicly as most others suggested
Re: this thing should mph better? [Re: dart443] #466814
09/13/09 05:07 PM
09/13/09 05:07 PM
BradH Offline
BradH  Offline
Various thoughts here...
- it may be a fuel supply issue, but I think it's more likely a combination issue
- Max Wedge-size Indy heads on 440-ish combinations don't work well from what I've been seeing, unless you spin the snot outta 'em (and your cam and intake choice don't suit that approach)
- Demon 850 annular carb is an odd beast... pulls a lot of fuel through those boosters down low, then seems to choke at higher rpm
Re: this thing should mph better? [Re: BradH] #466815
09/13/09 05:10 PM
09/13/09 05:10 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Re: this thing should mph better? [Re: dart443] #466816
09/13/09 07:14 PM
09/13/09 07:14 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
the heads are ported. i tried shifting between 6500&7000 no change.
How about shifting it from 5900 to 6400. Short
shifting can do wonders at times. I would think
a 4500 stall but your 60 is good. I think the
825 Race Demon would be a better carb.
What is the RPM at the traps?
To me, it seems like a top end thing. Out of power
in the high rpm range? Maybe a 3.90 gear would be
better. Just some Ideas.
Snap your neck, mega G-force launch, is all I want!
Re: this thing should mph better? [Re: dart443] #466817
09/13/09 08:18 PM
09/13/09 08:18 PM
Before I would change anything I would try and figure out what the main problem is I would(if you can) take it back to the track and jet it up to see if you can jet it fat enough to slow the 1/4 MPH down, if you can't fix that first If you can jet it up enough to slow it down then your on your own on whats wrong and what to fix Never give up, you know there is a problem, thats the easy part usually, figuring out what is causing it can be the hard part Let us know what you find and do
Re: this thing should mph better? [Re: Cab_Burge] #466818
09/13/09 08:29 PM
09/13/09 08:29 PM
ontario canada
dart443 Offline OP
dart443  Offline OP
ontario canada
thanx for all the replies, ill be going back in two weeks,
Re: this thing should mph better? [Re: dart443] #466819
09/13/09 10:05 PM
09/13/09 10:05 PM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
Everyone is always down on the holley blue. I think people forget it was the standard forever. Lots of them running much faster vehicles than this guy has.
Not to say its not going bad.
Hell I used to run 9.2s with a carter electric.
Re: this thing should mph better? [Re: dart443] #466820
09/14/09 01:22 AM
09/14/09 01:22 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
newbee 68 dart 440 ez headed hughes cam 613&626 250 256, 410 gear.ran yesterday 1.47 60 out the door at 11.26 119. what wrong with this combo
I think with the dual plane intake, you really need a larger carb. My 451 with a 252/252 cam, 0.613" lift was using a M1 single plane intake, a 1" open spacer, and a Holley HP 1,000 cfm carb. Before I got the HP carb, I ran a Holley 850, and I had to really richen it to tune it, and this is at Denvers 5,800 ft altitude. The 1,000 cfm carb was jetted pretty close out of the box and the car was faster by about 0.2 second, and a few MPH.
I am not sure what altitude you are racing at, but the altitude here in Denver really slows my car down. The lowest altitude I have run at was Las Vegas, and the car wan 11.80's @ 115 MPH. Not great, but it is a #4,150 street car and I launch pretty easy for traction reasons stock suspension, with the large torsen bars, so not much weight transfer or traction.
Re: this thing should mph better? [Re: dart443] #466821
09/14/09 10:33 AM
09/14/09 10:33 AM
NC
440Jim Offline
440Jim  Offline
NC
indy-2 manifold
If that is the Indy 440-2 intake, it is a single plane, max-wedge ports, 4150 single four barrel.
Re: this thing should mph better? [Re: dart443] #466822
09/14/09 11:02 AM
09/14/09 11:02 AM
michigan
64ssmax Offline
64ssmax  Offline
michigan
compression 10.66,had the car on the chassis dyno peak torque at 5200 408
1.More compression works wonders on mopars. 2.What is the cam installed at?
3.Never liked any of demon carbs. borrow a different brand.
4.Call ATI and talk to tech dept. ask them what convertor might be needed.
5.I would think shifting anything over 6500 with this combo the tongue is hanging out of the car.
lots of good advice from previous replys.
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end"
Re: this thing should mph better? [Re: 440Jim] #466823
09/14/09 11:24 AM
09/14/09 11:24 AM
BradH Offline
BradH  Offline
indy-2 manifold
Ooops... I was thinking the same thing ("-2" = 2-plane).
Still, if he does have that big single-plane intake, it's not helping the torque in the range where his cam is best suited. I'm actually surprised it 60-fts as well as it does w/ the rest of the parts mentioned.
Re: this thing should mph better? [Re: BradH] #466824
09/14/09 12:17 PM
09/14/09 12:17 PM
ontario canada
dart443 Offline OP
dart443  Offline OP
ontario canada
cam is installed at 104.5,single plane manifold
Re: this thing should mph better? [Re: dart443] #466825
09/14/09 01:27 PM
09/14/09 01:27 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
He has a 3/8 fuel line and pick up which I thought should be larger. maybe something to the lean as even though it has pretty big jets it showed lean on the plugs a few races back?
with that big intake and max wedge port EZ's I'd be shifting it 7200 to 7400!!
Re: this thing should mph better? [Re: dart443] #466826
09/14/09 04:18 PM
09/14/09 04:18 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Sorry, I mis-read the intake type.
I was running a 250 GPH pump and 1/2" (-8 AN) fuel line. On the Chassis Dyno the 451 HP peak was at 6100 RPM, so I usually shifted at 6500 RPM.
Re: this thing should mph better? [Re: Dodgem] #466827
09/14/09 04:33 PM
09/14/09 04:33 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Needs more fuel. Start here before doing anything else.
Re: this thing should mph better? [Re: dart443] #466828
09/14/09 07:07 PM
09/14/09 07:07 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I suggest that you first check your fuel pressure going through the traps. Pump type and idle fuel pressure is not enough information to determine if you have adequate fuel delivery all of the way down the track.
