this thing should mph better? #466789
09/13/09 07:54 AM
09/13/09 07:54 AM
ontario canada
dart443 Offline OP
dart443  Offline OP
ontario canada
newbee 68 dart 440 ez headed hughes cam 613&626 250 256, 410 gear.ran yesterday 1.47 60 out the door at 11.26 119. what wrong with this combo
Re: this thing should mph better? [Re: dart443] #466790
09/13/09 08:28 AM
09/13/09 08:28 AM
Q
Quicktree Offline
Quicktree  Offline
Q
Welcome really need more info, tire size,converter,weight etc. 60' looks good it's not making top end HP unless theres a problem elsewhere.
Re: this thing should mph better? [Re: Quicktree] #466791
09/13/09 08:39 AM
09/13/09 08:39 AM
ontario canada
dart443 Offline OP
dart443  Offline OP
ontario canada
quicktree, 325 et streets,3500 stall, 3400 lbs me in.850 mighty demon,indy-2 manifold
Re: this thing should mph better? [Re: dart443] #466792
09/13/09 08:46 AM
09/13/09 08:46 AM
Q
Quicktree Offline
Quicktree  Offline
Q
looks like it's just not making the power it should. I would have a bigger converter but you can't complain about the 60'. check timing and see if you can borrow a bigger carb. play with shift points.
Re: this thing should mph better? [Re: Quicktree] #466793
09/13/09 08:47 AM
09/13/09 08:47 AM
Q
Quicktree Offline
Quicktree  Offline
Q
are the heads ported? if not that should be the next thing you do.
Re: this thing should mph better? [Re: Quicktree] #466794
09/13/09 08:50 AM
09/13/09 08:50 AM
ontario canada
dart443 Offline OP
dart443  Offline OP
ontario canada
the heads are ported. i tried shifting between 6500&7000 no change.
Re: this thing should mph better? [Re: dart443] #466795
09/13/09 08:54 AM
09/13/09 08:54 AM
Q
Quicktree Offline
Quicktree  Offline
Q
check and make sure the throttle is open all the way. you have 60' for mid 10s. if your sure about the igniton and timing I would be looking at the carb maybe.
Re: this thing should mph better? [Re: Quicktree] #466796
09/13/09 08:59 AM
09/13/09 08:59 AM
ontario canada
dart443 Offline OP
dart443  Offline OP
ontario canada
timing at 39 degrees ignition all msd no missfire
Re: this thing should mph better? [Re: dart443] #466797
09/13/09 09:10 AM
09/13/09 09:10 AM
Q
Quicktree Offline
Quicktree  Offline
Q
try 34-36 just to see what happens.
Re: this thing should mph better? [Re: Quicktree] #466798
09/13/09 09:14 AM
09/13/09 09:14 AM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
If all else is in line its time for leakdown and compression checks.
68 Barracuda Formula S 340
Re: this thing should mph better? [Re: Bad340fish] #466799
09/13/09 09:27 AM
09/13/09 09:27 AM
ontario canada
dart443 Offline OP
dart443  Offline OP
ontario canada
checked throttle,tried 34 no change, fresh motor.25passes
Re: this thing should mph better? [Re: dart443] #466800
09/13/09 09:39 AM
09/13/09 09:39 AM
408Dust Offline
408Dust  Offline
Fuel system up to par? Have a fuel pressure gauge on it?
Re: this thing should mph better? [Re: dart443] #466801
09/13/09 09:41 AM
09/13/09 09:41 AM
Lehigh Acres, Florida
rickstershemi Offline
Actually I would be looking for a better ET with a 60' of 1.47.....119mph for an 11.26et is very good IMHO
Rickster
Re: this thing should mph better? [Re: 408Dust] #466802
09/13/09 09:45 AM
09/13/09 09:45 AM
ontario canada
dart443 Offline OP
dart443  Offline OP
ontario canada
holley blue,fuel gauge under hood set at 7 lbs.is a blue pump enough volume?
Re: this thing should mph better? [Re: dart443] #466803
09/13/09 09:54 AM
09/13/09 09:54 AM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
Whats the compression?
Way too big a cam for a 3500 stall converter. Im guessing that cam doesnt really come on to 5500 or so.
You have a 3500 stall converter and shifted at 6500 or 7K?
Bump that converter up to 4500 or higher (need all the facts). By the time the engine is making power your half way down the track.
1.47 is not great 60, but may be tire limited.
I think your combo is just too far apart on a few different areas.
Re: this thing should mph better? [Re: Garceau] #466804
09/13/09 10:02 AM
09/13/09 10:02 AM
ontario canada
dart443 Offline OP
dart443  Offline OP
ontario canada
compression 10.66,had the car on the chassis dyno peak torque at 5200 408
Re: this thing should mph better? [Re: dart443] #466805
09/13/09 10:04 AM
09/13/09 10:04 AM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
I definatly think your combo is a bit out of sorts.
I really dont like that carb.
Definatly need a looser converter.
As a side note, what are you trapping RPM at, and whats the diameter of your tires, and shift point. Have you checked the converters efficiency?
Re: this thing should mph better? [Re: rickstershemi] #466806
09/13/09 10:06 AM
09/13/09 10:06 AM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
Rickster
I think its because the converter is so tight. I had to do this once in my dart. Broke a converter through a bone stock one in there. Ran 1/2 second slower and same if not a touch more MPH. Was so tight if I put it in gear it would stall without some fancy footwork.
Re: this thing should mph better? [Re: dart443] #466807
09/13/09 10:24 AM
09/13/09 10:24 AM
NC
440Jim Offline
440Jim  Offline
NC
325 ET Street radials should be about 28" dia, with that 4.10 gear. I agree the sixty foot is good for the ET, my target sixty foot equation says that is what the following ET should be getting:
Sixty = 0.12xET + 0.17
ET = (Sixty-0.17)/0.12 = 10.83
My other curve fits to general cars in this league inputing 119 mph gives 11.25, so the mph and ET are in line.
More stall speed also improves ET during the shift recovery. Putting an 8" race converter around 5000 rpm would make it feel completely different.
That really isn't very much duration (250), but with your converter and 10.6 CR that is fine. Is that a roller cam? IMO, to take advantage of the heads (assuming decent port work) and the Indy MW intake, you would need to step up the converter and cam, limited by CR.
Re: this thing should mph better? [Re: 440Jim] #466808
09/13/09 10:33 AM
09/13/09 10:33 AM
ontario canada
dart443 Offline OP
dart443  Offline OP
ontario canada
440jim its a solid flat,do you think i am maxad out with this cam and convertor
