Are stock HP273 pistons forged or cast? #466747
09/13/09 12:28 AM
09/13/09 12:28 AM
Iowa
toolmanmike Offline OP
Iowa
I have heard conflicting stories but have never seen anything in print. Are the factory 10.5:1 Hp273
pistons forged or cast? How heavy are they? Thanks, toolmanmike
Re: Are stock HP273 pistons forged or cast? [Re: toolmanmike] #466748
09/13/09 12:33 AM
09/13/09 12:33 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have a couple 67 273 4-bbl engines apart and they are definitely forged and heavy! I also have a set of replacement forged pistons .030 over and they are real heavy!
JB Rhinehart, Realist
A-Body's RULE!
Re: Are stock HP273 pistons forged or cast? [Re: Rhinodart] #466749
09/13/09 01:42 AM
09/13/09 01:42 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
I never had a 235HP 273, but my old 2bbl 273 had really thick wall pins. I don't remember the pistons being overly heavy (by Chrysler standards), but the pin had about .300" thick wall. I think they did that to keep the same balance as a 318 piston and pin. It would make the assembly line easier if they could balance all the cranks the same.
Floyd Lippencott IV
Re: Are stock HP273 pistons forged or cast? [Re: Rhinodart] #466750
09/13/09 11:32 AM
09/13/09 11:32 AM
Mesa, Arizona
dart4forte Online boogie
dart4forte  Online Boogie
Mesa, Arizona
Are you sure you don't have the L2222 TRW Forged pistons. Every HP 273 I've torn apart had the 10.5 cast piston. Also, there is a secret to lightening the HP piston. Also as a note: EGGE shows a 4 barrel piston with the L2222 part number. However, after calling them I find that the piston they offer is the cast replacement piston. Really hard to find forged pistons for the 273 without going with the major manufacturers since their pistons are custom made and run around $600-$800 a set.
Re: Are stock HP273 pistons forged or cast? [Re: dart4forte] #466751
02/06/10 12:47 AM
02/06/10 12:47 AM
Iowa
Iowa
I bought a set of the Egge 10.5/1 pistons. They are cast and come with pins and clips. The +.030's are about 60 grams lighter than the stock standard bore slugs so I balanced the rotating assembly. They were all within a half a thousandth of the same size. Good stuff! Mike
Re: Are stock HP273 pistons forged or cast? [Re: toolmanmike] #466752
02/06/10 01:28 AM
02/06/10 01:28 AM
they are cast and as said the pins are very heavy so the 273 piston/pin assy will weigh the same as the 318 piston/pin assy even w the smaller dia (& therefore lighter) 273 pistons so the balancing bobweight is the same.
Re: Are stock HP273 pistons forged or cast? [Re: RapidRobert] #466753
02/06/10 09:42 AM
02/06/10 09:42 AM
Stockholm, Sweden
MrSixpack Offline
MrSixpack  Offline
Stockholm, Sweden
My 3 commando engines has cast pistons.
1970 Super Stock Challenger ex. Paul Rossi
1968 Dodge Dart GT 340
1968 Dodge Charger /6 3 speed manual
1966 Chrysler 300 Loaded
1968 Dodge Charger R/T 440
1968 Mini Cooper
Re: Are stock HP273 pistons forged or cast? [Re: Rhinodart] #466754
02/06/10 12:56 PM
02/06/10 12:56 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
So when the time comes around to repbuild my 273, I don't care about the 318 bobweight issue, what lightweight piston options are out there, custom or off the shelf?
Re: Are stock HP273 pistons forged or cast? [Re: Rhinodart] #466755
02/06/10 06:07 PM
02/06/10 06:07 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Got a pic of the underside?
