Re: Are stock HP273 pistons forged or cast?
[Re: Rhinodart]
#466750
09/13/09 11:32 AM
09/13/09 11:32 AM
Posts: 16,146 Mesa, Arizona
dart4forte
Mesa, Arizona
I have a couple 67 273 4-bbl engines apart and they are definitely forged and heavy! I also have a set of replacement forged pistons .030 over and they are real heavy!
Are you sure you don't have the L2222 TRW Forged pistons. Every HP 273 I've torn apart had the 10.5 cast piston. Also, there is a secret to lightening the HP piston. Also as a note: EGGE shows a 4 barrel piston with the L2222 part number. However, after calling them I find that the piston they offer is the cast replacement piston. Really hard to find forged pistons for the 273 without going with the major manufacturers since their pistons are custom made and run around $600-$800 a set.
[Re: dart4forte]
#466751
02/06/10 12:47 AM
02/06/10 12:47 AM
Posts: 21 Iowa
toolmanmike
Iowa
I bought a set of the Egge 10.5/1 pistons. They are cast and come with pins and clips. The +.030's are about 60 grams lighter than the stock standard bore slugs so I balanced the rotating assembly. They were all within a half a thousandth of the same size. Good stuff! Mike
[Re: toolmanmike]
#466752
02/06/10 01:28 AM
02/06/10 01:28 AM
RapidRobert
they are cast and as said the pins are very heavy so the 273 piston/pin assy will weigh the same as the 318 piston/pin assy even w the smaller dia (& therefore lighter) 273 pistons so the balancing bobweight is the same.
[Re: RapidRobert]
#466753
02/06/10 09:42 AM
02/06/10 09:42 AM
Posts: 952 Stockholm, Sweden
MrSixpack
Stockholm, Sweden
My 3 commando engines has cast pistons.
1970 Super Stock Challenger ex. Paul Rossi 1968 Dodge Dart GT 340 1968 Dodge Charger /6 3 speed manual 1966 Chrysler 300 Loaded 1968 Dodge Charger R/T 440
1968 Mini Cooper
