big block heads ?? #466382
09/12/09 02:17 PM
09/12/09 02:17 PM
Indiana
sipepuller Offline OP
Indiana
im getting ready to build a low deck stroker probly a 512 i have to run cast iron heads wich heads are the best to run for factory heads thanks Andy
Re: big block heads ?? [Re: sipepuller] #466383
09/12/09 04:06 PM
09/12/09 04:06 PM
Cab_Burge Online work
Cab_Burge  Online Work
286( I think?)1964(only) Max Wedge would be the best ever factory high deck or low deck heads, IMO
Re: big block heads ?? [Re: sipepuller] #466384
09/12/09 04:43 PM
09/12/09 04:43 PM
gregsdart Offline
gregsdart  Offline
Check Mancinis web sight. They have a pair of stage V heads, cheap. Those will make about 750 hp if maxed out with all the tricks in the motor.
