Comp XE 282s #466375
09/12/09 01:40 PM
09/12/09 01:40 PM
NE Indiana
momopar Offline OP
momopar  Offline OP
NE Indiana
Anyone run this, and what's the rest of the combo?
Firefighter had a dyno sheet a long while back comparing the 282 to the .590 M.P.
 The 282 made more H.P. and Tourque across the entire 6000 RPM range.
Wish I knew the rest of that combo i.e. compression etc.
Re: Comp XE 282s [Re: momopar] #466376
09/12/09 01:44 PM
09/12/09 01:44 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: Comp XE 282s [Re: 1_WILD_RT] #466377
09/12/09 02:41 PM
09/12/09 02:41 PM
NE Indiana
momopar Offline OP
momopar  Offline OP
NE Indiana
Re: Comp XE 282s [Re: momopar] #466378
09/12/09 03:25 PM
09/12/09 03:25 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
Will stock .600 lift Edelbrock head springs stand up to this cam?
Re: Comp XE 282s [Re: GwaiiEagle] #466379
09/18/09 11:03 AM
09/18/09 11:03 AM
NE Indiana
momopar Offline OP
momopar  Offline OP
NE Indiana
Any one else,
Why would you use the big cam if the smaller one rocks to 5800? I would guess from there on up the 590 blows the 282 out of the water!
Re: Comp XE 282s [Re: GwaiiEagle] #466380
09/18/09 12:13 PM
09/18/09 12:13 PM
Chicagoland
chargerron69 Offline
Chicagoland
comps Xe cams require more seat pressure than the eddy springs can handle, add an inner spring and it should be cool
67 Coronet 383 hogged out 906's 727 430 dana best 10.48 @126.80 1.47 60 on fogger same car pump gas 605 wedge 9.98 @ 138.42 1.50 60 on wore out 9 inch radial slick ss springs and frame connectors its got more in it!!! 72 Newport 2 door 400 727 85 Ram 440 4 speed O/D 3.54 dana
Re: Comp XE 282s [Re: chargerron69] #466381
09/18/09 12:21 PM
09/18/09 12:21 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
I'm running the XE290S with Edelbrock RPM heads with their stock springs. Doesn't seem to be a problem.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
