You are my hero,
Too bad it's not a real bird cuz it's more fun that way.
You have a ton of body roll happening.
My
Put ducted air on the front rotors and I hope you lost the splash shields.
Set the preload on the front wheel bearings to about 100 inch lbs. Use a beam type torque wrench.
Large front T bars needed badly
QA1 shocks and some competition tires...Toyo makes them in many sizes now...will make the biggest difference.
As for whoa to stop the go, if you can get Andy to whip up some adapters to use the wilwood dyna lite caliper there is a pad compound I am using that works really well [does not noticeably fade] and has good balance with carbon metallic shoes on the rear. I will go look for the info.
Banzai!!!
Watkins Glen June 2009, yes it's real
