Calculating compression ratio? #465503
09/11/09 09:41 AM
09/11/09 09:41 AM
Suffolk,VA
I
ireland383 Offline OP
I
Suffolk,VA
Forgive me for not knowing how, but it seems Chinese to me. 71 383 original 2 barrel,KB 400 .040 pistons http://kb-silvolite.com/performance.php?action=details&P_id=327,block was cleaned up not shaved. Thanks Forgot .039 felpro 8519 and Stealth heads 84cc
Re: Calculating compression ratio? [Re: ireland383] #465504
09/11/09 09:45 AM
09/11/09 09:45 AM
click tech info at the top of the site then click calculators & you'll access the CR calculator to plug your specs into.
Re: Calculating compression ratio? [Re: RapidRobert] #465505
09/11/09 09:48 AM
09/11/09 09:48 AM
Suffolk,VA
I
I
Suffolk,VA
Yeah, I tried and got lost. Don't know the deck height. I was hoping someone knew for 71.
Re: Calculating compression ratio? [Re: ireland383] #465506
09/11/09 01:43 PM
09/11/09 01:43 PM
Suffolk,VA
I
I
Suffolk,VA
Anyone wanna take a stab at it?
Re: Calculating compression ratio? [Re: ireland383] #465507
09/11/09 01:54 PM
09/11/09 01:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
well the blueprint spec for a LOW DECK which is for ALL B engines is 9.980 , what yours is ??? you COULD have one of the MYTHICAL blocks I hear of that are TALLER than spec .
Re: Calculating compression ratio? [Re: JohnRR] #465508
09/11/09 02:05 PM
09/11/09 02:05 PM
Suffolk,VA
I
I
Suffolk,VA
Assuming it is 9.980, what would that calculate to?
Re: Calculating compression ratio? [Re: ireland383] #465509
09/11/09 02:11 PM
09/11/09 02:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what i looked at didn't ask for deck , i got 9.5
Re: Calculating compression ratio? [Re: JohnRR] #465510
09/11/09 02:14 PM
09/11/09 02:14 PM
Suffolk,VA
I
I
Suffolk,VA
Which calculator did you use?
Re: Calculating compression ratio? [Re: JohnRR] #465511
09/11/09 02:15 PM
09/11/09 02:15 PM
WA 98043
thecarfarmer Offline
WA 98043
Theoretically, your engine should assemble with the pistons .024 down the bore... if you got the mythical 'perfect' block Jonahah was referring to.
How much farther down - who knows?
Also, these decks aren't always level to the crank center; sometimes one end of the deck is higher than the other. My block was so out-of-square that the machinist ended up cutting enough off that I ended up with pistons ABOVE the deck a few thou (longer rods, stroker crank).
Also, I've read here from guys that CC'd their Sourcerer heads (I didn't bother w/ mine, 'cause they'll be coming back off for porting anyway) that they actually run between 84 and 86 CC's.
Plugging all that into my handy-dandy spreadsheet (that moparts member Schwep designed), your CR calculates out to 9.56:1 with 'perfect' deck and 84 CC chambers, and a marginal .062" quench distance.
With 86 CC chambers, and .015" extra on the deck (I pulled that out of my hat as a 'bad case'), your CR drops to 9.08 and the quench distance grows to a poor .077".
FWIW, you're into the $$$ for pistons, heads, etc; I'd think strongly about checking the deck height, see where you're at, and get that quench down to the .035-.045 range.
-Bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: Calculating compression ratio? [Re: thecarfarmer] #465512
09/11/09 02:24 PM
09/11/09 02:24 PM
Suffolk,VA
I
I
Suffolk,VA
I hear you on just slapping them on because they will come off for more work later as funds come in. Then I can get a true deck height. Another reason for this post was a while back I posted about my 346's feeling like they had more power. Those were shaved .30 originally 88cc to 82cc. I'm not sure if that made a big differance being they were open chamber.
Re: Calculating compression ratio? [Re: thecarfarmer] #465513
09/11/09 05:38 PM
09/11/09 05:38 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
-Bill
Bill the MYTHICAL blocks I speak of are the ones that are TALLER than stock .
Re: Calculating compression ratio? [Re: JohnRR] #465514
09/11/09 06:15 PM
09/11/09 06:15 PM
WA 98043
WA 98043
Oh, my bad.
I thought the 'hens teeth' were the ones that were a) blueprint spec height, and b) the same front-to-back and side-to-side.
Of course, there must have been something from Ma MoPar that got done 'on the money', but it never seems to have got traded for MY money...
FWIW, I'd just call the CR a nominal 9.2 and be done w/ it, unless I wanted to pull the heads off.
-Bill
Re: Calculating compression ratio? [Re: thecarfarmer] #465515
09/12/09 10:47 AM
09/12/09 10:47 AM
Suffolk,VA
I
I
Suffolk,VA
Last ? on this topic is there a problem with running the kb400's with the stealths and flame travel?
Re: Calculating compression ratio? [Re: ireland383] #465516
09/12/09 11:06 AM
09/12/09 11:06 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The dome can be an issue with flame travel no matter what head it is , the best way to get the compression you want is to get a custom flat top piston made and cut the heads for a smaller chamber size.
Bill, the blocks, in my opinion, are different end to end and corner to corner, in part because the block has settled, been seasoned if you will, I really doubt the block was machined like that when new.
Re: Calculating compression ratio? [Re: JohnRR] #465517
09/22/09 10:25 AM
09/22/09 10:25 AM
Suffolk,VA
I
I
Suffolk,VA
Would I measure the flat part of the piston or the dome to get the deck height?
Re: Calculating compression ratio? [Re: ireland383] #465518
09/22/09 11:14 AM
09/22/09 11:14 AM
Would I measure the flat part of the piston ?
yes
