I have some SB heads that I want to open up the pushrod pinch but Ive punched through a couple on other sets. Just to be safe and get a good window, I want to put some sleeves in. What do you guys use, bronze or brass? What to you use to hold them in? What OD tubing did you use? Thanks!
