Re: Electrical Short?!
[Re: warpspeed]
#465242
09/10/09 09:13 PM
09/10/09 09:13 PM
Posts: 319 Denver
Explodo
Denver
Check your block to body and negative to block grounds?
'67 440 Satellite
[Re: warpspeed]
#465247
09/11/09 08:04 PM
09/11/09 08:04 PM
RapidRobert
You might check your voltages at the ign sw terminals ign1 (run) & ign2(crank) & especially pull apart the bulkhead & check your voltage drops there also.
[Re: warpspeed]
#465249
09/11/09 08:15 PM
09/11/09 08:15 PM
RapidRobert
I think it'd run but not right. iirc the green MSD wire (neg) goes to the black oe wire (neg) on the Mopar dist.
[Re: warpspeed]
#465251
09/11/09 08:39 PM
09/11/09 08:39 PM
RapidRobert
I'm not sure because I've never had a MSD & the dist pickup polarity just stuck in my head & I prefaced it with an iirc as I was not sure. I do think the large (MSD)red/black leads go directly to the battery then a small red switched 12V to energise it. I better stop there as I did not pay close attention as I figured I'd be too poor to ever afford an MSD (but I'd like to have the multispark).
[Re: RapidRobert]
#465252
09/11/09 08:57 PM
09/11/09 08:57 PM
Posts: 101 South Carolina
warpspeed
South Carolina
Thanks rapidrobert. I have been going back to another of your discussions a few days ago. Putting everything together, I think that the MSD is not getting continuous voltage AFTER the starting circuit. I have tried to write to the MSD people without an answer. But, I think that it needs power from the ign 1. On the other two cars, I have a resistor on each car in the standard location without problems. So, that is what I am going to do after recharging my battery again. I agree that the MSD cost more than a ECU, but, added together, it isn't that much more. I probably don't really see a big difference, but, my engine doesn't run as well with the new cam as it did before, so I thought I would try it. I am beginning to think the heads aren't big enough for this cam. BUT, I can 't get the car to start/run with the new MSD. I am ready to go back to the old ECU if this doesn't work. Thanks for your help.
[Re: warpspeed]
#465254
09/22/09 06:15 PM
09/22/09 06:15 PM
warpspeed
South Carolina
Well guys, something is still wrong. Why does the engine start with the distributor at one setting, location one I will call it, run great when adjusted to equal the proper timing, that is; location two, that is with maximun timing without vaccum at 35 plus/minus, vaccum connected shows a solid 52. It runs well, still needs to have the carb adjusted to the larger cam, (I think that is it) but will not start again after shut down without resetting the distributor back to location one that is described above. It will start hard, run rough, then let me adjust it to location two where it runs smoothly agian. Shut it down, and here we go again. I checked the two distributor wires and made sure that the green lead wire from the MSD is connected to the black wire to the distributor. Oh yeah, I switched these two wires and absolutely couldn't get the mark on the flywheel to line up at all with the timing mark. Looks like it was backward. BUT, I am not sure. Any suggestions?
Just an update. It turns out that the distributor has been messing up my trouble shooting assessment. The distributor has been advancing too far forward after adjusting the timing to the mechanical 3000 RPM. I hope you know what I mean when I say this. The engine was way out of position for "starting" timing. It would not start. Since the old distributor, which wasn't causing any problems, has a vaccum adjuster, I am swapping the old distributor for the new one and hoping that this will solve my problems. yeah!!!!
