Car sits higher after replacing balljoints? A-body #465215
09/10/09 07:59 PM
09/10/09 07:59 PM
Deweyville, UT
RUDF1 Offline OP
super gas
RUDF1  Offline OP
super gas
Deweyville, UT
Hello all
Is it normal for the frontend to be noticeably higher after replacing upper and lower balljoints (on both sides)? I replaced both balljoints on both sides of the 73 Dart, now much higher than before. Should I just back off a bit on the torsion bars?
Eric
1971 Dart GT 1973 Dart Swinger
Re: Car sits higher after replacing balljoints? A-body [Re: RUDF1] #465216
09/10/09 08:03 PM
09/10/09 08:03 PM
Myrtle Beach, SC formerly the ...
340wedge Offline
340wedge  Offline
If the front has been off the ground it takes a little bit for it to settle back to the normal ride height. Mine usually takes a few hours
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
Re: Car sits higher after replacing balljoints? A-body [Re: RUDF1] #465217
09/10/09 08:05 PM
09/10/09 08:05 PM
the house on the left.
cogen80 Offline
cogen80  Offline
have you driven the car yet?
Re: Car sits higher after replacing balljoints? A-body [Re: cogen80] #465218
09/10/09 08:46 PM
09/10/09 08:46 PM
Deweyville, UT
RUDF1 Offline OP
super gas
RUDF1  Offline OP
super gas
Deweyville, UT
Been 2 days, have bounced the bumper a few times but not driven. Tires show noticeable camber, didnt want to drive with for sure tire edge wear.
Re: Car sits higher after replacing balljoints? A-body [Re: RUDF1] #465219
09/10/09 09:01 PM
09/10/09 09:01 PM
MNobody Offline
MNobody  Offline
Try turning the wheels all the way left and right, if that don't work just drive it a short ways and check again. My Dart always sits higher after jacking up the front end until i crank the wheels or drive it.
Re: Car sits higher after replacing balljoints? A-body [Re: MNobody] #465220
09/10/09 10:10 PM
09/10/09 10:10 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Move it around a bit, take it for a short trip around the block, then check to see if you need to adjust for height.
Re: Car sits higher after replacing balljoints? A-body [Re: RUDF1] #465221
09/10/09 10:31 PM
09/10/09 10:31 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Changing the ball joints - did you change the adjustment on the torsion bars? Did you remove the control arms and change the alignment cam settings?
Regardless, get the factory service manual and read up on how to measure the front end ride height and how to correct it.
After you get the ride height set take it in for an alignment.
