Re: Old gas
[Re: Wilkram]
#465126
09/10/09 06:48 PM
09/10/09 06:48 PM
Posts: 319 Denver
Explodo
Denver
The tank might be the least of your worries. The lines themselves are sitting with gas in them also.
'67 440 Satellite
Re: Old gas
[Re: Wilkram]
#465129
09/10/09 07:24 PM
09/10/09 07:24 PM
Posts: 319 Denver
Explodo
Denver
No, but they need to be cleaned out really well or they'll just end up gumming up things. I'm not sure how bad gas gets over 2 years though.
'67 440 Satellite
Re: Old gas
[Re: 69B3GT]
#465131
09/11/09 10:51 AM
09/11/09 10:51 AM
Posts: 304 Ohio
LS-300
Ohio
My car had sat for more that 5 years. What I did was disconect the fuel line at the pump and install an electric pump with the output run to a 5 gal gas can. After I drained all the old fuel I hooked it all back up and put fresh fuel in. I then drove the car. I've had no problems. As for the old fuel I mixed it with some fresh and used it in my lawnmower.
1979 Chrysler 300
1968 Barracuda project
Re: Old gas
[Re: Wilkram]
#465133
09/11/09 01:50 PM
09/11/09 01:50 PM
I have a 74 Charger SE with 318. It's been sitting for just over 2 years with about 1/4 tank of gas in it. How can I take care of the old gas without dropping the tank. On a very tight budget.
Is the gas "bad" as in it won't run on it?
If it will run with the old gas, I'd say run it... Add some fresh gas, the higher octane the better, to help dilute the old fuel.
As long as it hasn't turned to varnish you shouldn't have to tear it apart.
If it has the suggestions already mentioned are good.
-Or- You can pick up a fluid transfer pump from harbor freight cheap. Pump out the tank from the filler tube. Disconnect the line at the tank and at the pump, connect the HF pump and pump fresh gas (from a clean container) thru the line. Do the same from the pump to carb line also.
Or easier yet... pump out the tank, add fresh gas, disconnect at carb, prime carb with fresh gas, take disconnected line from carb and put into 5 gallon bucket (or other suitable container), then run car at idle and let the pump suck fresh gas from the tank to flush the system.
If the carb is gummed up with varnish that's gunna be another project in itself...
Disclaimer: Just suggestions to help solve your problem in an inexpensive way. Be sure to use common sense with flammables otherwise your problems will grow as fast as the fire does...
