Carb running rich ***update*** #465107
09/10/09 06:44 PM
09/10/09 06:44 PM
Chi-Town
PlumCrazyCharger Offline OP
Chi-Town
Put a more street/strip engine in the 69. 440 with sr heads, 9.5 to 1 comp, 35 degrees timing, hydralic cam 520ish lift, 3.73 gears.
Problem is it's running very rich at idle/low speed. Have a Quickfuel 750 vac secondary carb with a torker 2 intake. Primary jet is 76 and secondary jet is 78. Has a power valve, but don't know the number. Would the power valve affect the richness? I don't have an 02, but plugs are dead rich and eyes burn.
Also it gets bad mileage. Maybe 4-5 MPG cruising on the highway at 65 (~2800 RPM). I use to get that MPG with a bigger cam and dominator.
Any ideas????
Re: Carb running rich [Re: PlumCrazyCharger] #465108
09/10/09 07:24 PM
09/10/09 07:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Any ideas????
Yes the PV will effect the idle if its open already,
it would be dumping fuel.... check your vac at idle
in gear and get a PV about 2" lower than the idle
vac number..... plus your jet sizes dont jive with
running a PV... the PV side, the jets should be
8 jet sizes smaller than the non-jet side
Re: Carb running rich [Re: PlumCrazyCharger] #465109
09/10/09 07:27 PM
09/10/09 07:27 PM
UK
602heavy Offline
602heavy  Offline
UK
Power valve circuit does'nt come into play @ idle , the PV channel will only flow fuel when main metering starts , is this a new carb out the box? , is the PV gasket in tact/PV blown , is the motor idling on the mains? (trans slot too far exposed) , float level set to high? , N&S seating ok? , too much fuel pressure? , timing too far retarded @ idle? IABs blocked, pump umbrella seals?
Re: Carb running rich [Re: 602heavy] #465110
09/10/09 07:32 PM
09/10/09 07:32 PM
UK
602heavy Offline
602heavy  Offline
UK
Maybe start with a 70 PMJ/78 SMJ
Re: Carb running rich [Re: PlumCrazyCharger] #465111
09/10/09 07:36 PM
09/10/09 07:36 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Make sure your not dumping fuel,then you need to use a vacume gauge and verify the p/v size.What will it idle at??Have you tried the idle adjustmants?
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Carb running rich [Re: 602heavy] #465112
09/10/09 07:38 PM
09/10/09 07:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This is what I was trying to say... if its open/blown
or the transfer slot open too far
Re: Carb running rich [Re: MR_P_BODY] #465113
09/10/09 07:41 PM
09/10/09 07:41 PM
UK
602heavy Offline
602heavy  Offline
UK
Mr P , i posted before i saw you're post , so was'nt disagreeing as i never read you're post anyhow.
Re: Carb running rich [Re: 602heavy] #465114
09/10/09 07:45 PM
09/10/09 07:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
LOL....
Re: Carb running rich [Re: 602heavy] #465115
09/10/09 07:48 PM
09/10/09 07:48 PM
Chi-Town
Chi-Town
Sorry doubled checked jets and 76 primary, 86 secondary.
I have 5-6 inches of vacuum in gear. Looks like the power valve is a 4.5 in the carb now. Seems like the rubber diaphram is ok. How can I check? I do have another 3.5 PV from another carb.
Carb is not new but I went thru it. It was originally setup up for a higher compression engine. It does have air bleeds. Doesn't seem to be dumping fuel when I look over the carb.
Do I have to run a PV? Whats it's purpose?
All 4 idle screws are 1.5 out and fuel pressure is set at 7 lbs. Floats are set and needle and seat's are good.
It's not puffing smoke like crazy, just enough to burn your eyes. I could jet down to 70's as suggested. Would that help with the mileage also?
Thanks for the replies.
Sean
Re: Carb running rich [Re: PlumCrazyCharger] #465116
09/10/09 10:47 PM
09/10/09 10:47 PM
New York
polyspheric Offline
polyspheric  Offline
New York
You need more initial spark lead to get those blades closed up and shut off the PV.
Boffin Emeritus
Re: Carb running rich [Re: polyspheric] #465117
09/11/09 01:42 PM
09/11/09 01:42 PM
Chi-Town
Chi-Town
Well found the springs for the MSD billet distributor. Never thought of that until the suggestions from you guys. I had 28 degrees retard on the distributor! Changed the bushing to only have 10 degrees and so at idle I have 24 degrees timing and 34 degrees overall. Now it idles better and not rich. As Poly said now I can back down the idle screw for and not open the power valve or jump into the main circuit.
Thanks for all the ideas!
Re: Carb running rich [Re: PlumCrazyCharger] #465118
09/11/09 02:14 PM
09/11/09 02:14 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
To my knowledge the largest bush gives 18 degrees advance, the only way i could get 10 was to use the FBO bushes.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Carb running rich [Re: PlumCrazyCharger] #465119
09/11/09 02:16 PM
09/11/09 02:16 PM
wisconSIN
Blown61 Offline
Blown61  Offline
wisconSIN
http://www.holley.com/TechService/Library.asp
Re: Carb running rich [Re: Blown61] #465120
09/11/09 04:24 PM
09/11/09 04:24 PM
Chi-Town
Chi-Town
Not sure about the 18 degrees. I checked my timing and it's 10 degrees diff. 24 at idle and 34 at 2000 RPM. Let you guys know on Sunday how it works!
Re: Carb running rich [Re: PlumCrazyCharger] #465121
09/11/09 09:18 PM
09/11/09 09:18 PM
UK
602heavy Offline
602heavy  Offline
UK
Maybe you got vac advance hooked up.
Re: Carb running rich [Re: PlumCrazyCharger] #465122
09/11/09 10:51 PM
09/11/09 10:51 PM
at 2000 rpm your probably not at full advance yet. i'd check it at 3500.
also, you shouldn't need 1.5 turns out for your combo at idle on all four screws. you've made it idle better, but i bet you can still improve on that.
Re: Carb running rich #465123
09/12/09 10:05 PM
09/12/09 10:05 PM
Chi-Town
Chi-Town
Yes fully advanced at 1800 RPM. Wow drove to Rt.66 today and got ~14 MPG only took 4.2 gallons to go 65 miles!
Re: Carb running rich [Re: PlumCrazyCharger] #465124
09/12/09 10:17 PM
09/12/09 10:17 PM
that's great !!! which springs and bushing are you using in the distributor?
