Re: Master Cylinder replacement with trailer brakes
[Re: SPWC]
#464750
09/10/09 12:09 PM
09/10/09 12:09 PM
Posts: 5,140 East Aurora (Buffalo) NY
RoadRunner
Yep, that is on old brake controller unit. I would not reuse it. You can get a nice electric break controller from Tekonsha (I have the Prodigy) that has proportional brake signal and is very adjustable. I assume your trailer has electric brakes.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: RoadRunner]
#464751
09/10/09 12:19 PM
09/10/09 12:19 PM
Posts: 4,760 Moved to N.E. Tennessee
GomangoCuda
X2 I would also recommend changing over to a Prodigy. Best controller I have used.
[Re: SPWC]
#464753
09/10/09 12:52 PM
09/10/09 12:52 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Does that controller have a bleeder and if so does it open? If you open the lines at the master the system will need to be bleed.
If yes then you can leave it and just bleed it alnog with everything else.
If the answer to either is no then I would recomend removing it, and the T fitting and returning the brakes to their as factory plumbing.
