Master Cylinder replacement with trailer brakes #464746
09/10/09 11:40 AM
09/10/09 11:40 AM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
My 73 Dodge D200 has a master cylinder I might need to replace as I cant find a gasket for the lid. The port for the front brakes has a TEE for the brake line going to the trailer brakes that have been installed in the truck
Question I have is,if and when I do replace the master cylinder,will this tee play any part in bleeding the brakes once the master is installed?
Is there a difference in how brakes are bled when trailer brakes are installed?
Re: Master Cylinder replacement with trailer brakes [Re: SPWC] #464747
09/10/09 11:48 AM
09/10/09 11:48 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
huh ???
I have never see trailer brakes plumbed to the tow vehicle ???
Re: Master Cylinder replacement with trailer brakes [Re: JohnRR] #464748
09/10/09 12:01 PM
09/10/09 12:01 PM
SPWC Offline OP
SPWC  Offline OP
Call me crazy,but that sure is what it looks like to me. Take a look at these pictures,I got this truck from a friend,and it was this way when he got it. I have no knowledge about trailer brakes.
Here you can see the "TEE" and the lines coming off the master. One line goes off the tee back into the firewall/interior and hooks up to the back of the trailer brake unit under the dash.
Re: Master Cylinder replacement with trailer brakes [Re: SPWC] #464749
09/10/09 12:03 PM
09/10/09 12:03 PM
SPWC Offline OP
SPWC  Offline OP
Here a view of the back of the trailer brake controller where the line coming through the firewall attaches to.Dont ask me...I know nothing about these things.
Re: Master Cylinder replacement with trailer brakes [Re: SPWC] #464750
09/10/09 12:09 PM
09/10/09 12:09 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Yep, that is on old brake controller unit. I would not reuse it. You can get a nice electric break controller from Tekonsha (I have the Prodigy) that has proportional brake signal and is very adjustable. I assume your trailer has electric brakes.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Master Cylinder replacement with trailer brakes [Re: RoadRunner] #464751
09/10/09 12:19 PM
09/10/09 12:19 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
X2
I would also recommend changing over to a Prodigy. Best controller I have used.
Re: Master Cylinder replacement with trailer brakes [Re: GomangoCuda] #464752
09/10/09 12:25 PM
09/10/09 12:25 PM
SPWC Offline OP
SPWC  Offline OP
I dont own a trailer,and am not sure if I would ever use this truck to tow. So basically this brajke controller is a mechanical/hydraulic unit,where the modern ones are electric?
So IF I decide to keep the trailer brakes as they are,will this play any part in replacing the master cylinder and bleeding the brakes? Anything additional I have to do because of the brake controller concerning bleeding of the brakes?
Re: Master Cylinder replacement with trailer brakes [Re: SPWC] #464753
09/10/09 12:52 PM
09/10/09 12:52 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Does that controller have a bleeder and if so does it open? If you open the lines at the master the system will need to be bleed.
If yes then you can leave it and just bleed it alnog with everything else.
If the answer to either is no then I would recomend removing it, and the T fitting and returning the brakes to their as factory plumbing.
Re: Master Cylinder replacement with trailer brakes [Re: GomangoCuda] #464754
09/10/09 03:41 PM
09/10/09 03:41 PM
Az
Crizila Offline
Crizila  Offline
Az
X2
X3 best one on the market for the $. Hydraulic pressure as a trailer brake sensor technology went away in the 80's - and a good thing it did!
Fastest 300
Re: Master Cylinder replacement with trailer brakes [Re: SPWC] #464755
09/10/09 04:07 PM
09/10/09 04:07 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Chris if your going to replace the master I would remove the "T". Leaving it in will be more trouble than its worth. Pull the rest of the controller stuff if you want to but be sure to disconnect the electrical to/from it at least.
