Superbee Hoodpin bumpers #464602
09/09/09 10:43 PM
09/09/09 10:43 PM
Auburn Hills, Michigan
K
kieron_kohlmann Offline OP
K
does the rubber bumpers for the hood pins. does it go through the inner support of the hood. right now when i set my hood on the car it is resting on the hoodpin nut and there is no room for the rubber spacer.
Re: Superbee Hoodpin bumpers [Re: kieron_kohlmann] #464603
09/10/09 05:59 AM
09/10/09 05:59 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Your question is hard to follow the way it's written.
What are you working on?
I can't afford this. mark
Re: Superbee Hoodpin bumpers [Re: kieron_kohlmann] #464604
09/10/09 09:13 AM
09/10/09 09:13 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
wow, you need to better explain yourself.
The bumper should not go through the inner support.
logan426
Re: Superbee Hoodpin bumpers [Re: kieron_kohlmann] #464605
09/10/09 10:57 AM
09/10/09 10:57 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
I believe you are referring to a Six Pack fiberglass hood for an A12 Bee? If so, the sections of rubber hose over the pin actually go through the underbracing of the hood which leaves the top layer of the hood resting on top of the rubber hose.
