Re: two step
[Re: MikeyT]
#464236
09/09/09 08:33 PM
09/09/09 08:33 PM
Posts: 2,110 toledo, ohio
plasticfantastic
toledo, ohio
What is a 2 step?
Mike
a type of country dance...
a two step holds the RPM of the car at a pre determined rpm while on the starting line, (the throttle is floored, the rpm stays at 3500 (for example), let go of the button and the 3500 limit goes away and now you have your rev limiter. (two settings, two step) there are more technical and more involved explinations that i'm sure people will post, and repost and then verify as being correct,
Re: two step
[Re: plasticfantastic]
#464238
09/09/09 09:54 PM
09/09/09 09:54 PM
Posts: 871 WA 98043
thecarfarmer
WA 98043
What is a 2 step?
Mike
Re-posted and verified for correctness.
Sorry, I just couldn't help it...
-Bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: two step
[Re: Aspen7695]
#464240
09/10/09 08:04 AM
09/10/09 08:04 AM
Posts: 722 Hampstead, MD.
Troublemaker427
Hampstead, MD.
I run mine hooked to the brake lights. I've never had a problem with it misfiring or doing anything funny in the shutdown.
Jody Aberts
1966 Fairlane 427
Troublemaker2
AA/NSS
1964 Galaxie 500XL
390-4spd.
1966 F-100
390-C6
1967 Plymouth VIP
383-TF
2003 Roadking
