two step #464232
09/09/09 07:53 PM
09/09/09 07:53 PM
wisconsin
little340 Offline OP
wisconsin
does anybody have there 2-step button located in there brake pedal. how well does it work. tried to put it in steering wheel but everytime you turn the cord wraps around steering column. maybe there is a better place to put it. any ideas would be helpfull.
Re: two step [Re: little340] #464233
09/09/09 08:07 PM
09/09/09 08:07 PM
KYbywayof WV
Frito Offline
Frito  Offline
KYbywayof WV
Barton did have one on the pedal of Carps A/SA last year but I am not sure if it is still there. If that is how he had the SS/AH car at Indy, it did not work in the final.
Re: two step [Re: Frito] #464234
09/09/09 08:13 PM
09/09/09 08:13 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Many stock elimanator racers put it on the metal arm just above the brake pedal pad. This way they won't hit accidentally at the finishline. They also put in series with the shifter in first gear only. Any normally open momentary switch should work.
Re: two step [Re: nss guy] #464235
09/09/09 08:27 PM
09/09/09 08:27 PM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
What is a 2 step?
Mike
1969 Dodge Dart Swinger
Re: two step [Re: MikeyT] #464236
09/09/09 08:33 PM
09/09/09 08:33 PM
toledo, ohio
plasticfantastic Offline
toledo, ohio
What is a 2 step?
Mike
a type of country dance...
a two step holds the RPM of the car at a pre determined rpm while on the starting line, (the throttle is floored, the rpm stays at 3500 (for example), let go of the button and the 3500 limit goes away and now you have your rev limiter. (two settings, two step)
there are more technical and more involved explinations that i'm sure people will post, and repost and then verify as being correct,
Re: two step [Re: little340] #464237
09/09/09 08:51 PM
09/09/09 08:51 PM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
I ran my two step from the module to a toggle switch by the shifter and to the brake light switch. That way I can use the two step from the brake pedal and at the big eng turn the toggle switch off prior to hitting the brakes. I was worried about the engine misfireing at the big end when I hit the brakes.
6.50 @105.26
Re: two step [Re: plasticfantastic] #464238
09/09/09 09:54 PM
09/09/09 09:54 PM
WA 98043
thecarfarmer Offline
WA 98043
What is a 2 step?
Mike
Re-posted and verified for correctness.
Sorry, I just couldn't help it...
-Bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: two step [Re: thecarfarmer] #464239
09/09/09 10:13 PM
09/09/09 10:13 PM
Gilbert, AZ
Aspen7695 Offline
Aspen7695  Offline
Gilbert, AZ
Mine is on the brake pedal. I have a micro switch that is activated by the shifter handle. When I put the shifter into high gear it pushes the switch and deactivates the 2 step.
Raul
Re: two step [Re: Aspen7695] #464240
09/10/09 08:04 AM
09/10/09 08:04 AM
Hampstead, MD.
Troublemaker427 Offline
Hampstead, MD.
I run mine hooked to the brake lights. I've never had a problem with it misfiring or doing anything funny in the shutdown.
Jody Aberts 1966 Fairlane 427 Troublemaker2 AA/NSS 1964 Galaxie 500XL 390-4spd. 1966 F-100 390-C6 1967 Plymouth VIP 383-TF 2003 Roadking
