I have no front brakes. Why? #464077
09/09/09 06:12 PM
09/09/09 06:12 PM
Nebraska
FASTBACK66 Offline OP
mopar addict
mopar addict
Nebraska
I am changing over my 1966 Charger from 4 wheel manual drum to manual disc front drum rear. I got my spindles and calipers from a 1978 LeBaron and my aluminum master cylinder from a mid eighties Cop car Diplomat. I have a prop valve/ distribution block on it from a 1967 Satellite when I had switched from the single resoviour to the dual. To begin with I used my factory pedal rod, and started to bleed the system at the right rear. Went normal. Then left rear. Went normal and began to get a little resistance in the pedal. But nothing at the front. No resistance in the pedal and no fluid. I bleed the M/C twice now and tried bleeding the front lines at the prop valve but nothing. No pressure or resistance. It acts like my pedal isn't going deep enough into the M/C bore to push the front. But it worked fine when I bleed it on the car at the M/C. Where else could the problem be. We blew compressed air into each line individually to eliminate a blockage but still nothing. Air came out it's respective side from the prop. valve as it should. It's just a dead pedal. Is my M/C bad? Or do I need a certain one from a different application?
Thanks, Vinny
Re: I have no front brakes. Why? [Re: FASTBACK66] #464078
09/09/09 06:47 PM
09/09/09 06:47 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Did you 'bench-bleed' the MC properly?
(as in feeding the outputlines into the bowls and pumping slowly for about 10 minutes and some intervals till no bubbles are in it)
Did you perhaps install the front and rear brakelines the wrong way around on the MC?
Usually the rear bowl (nearest to the firewall) is the one for the front brakes. It's usually also the larger bowl in the MC.
Re: I have no front brakes. Why? [Re: BigBlockMopar] #464079
09/09/09 07:26 PM
09/09/09 07:26 PM
I'd suspect air still in the M/C (firewall half) & if not R&R the M/C.
Re: I have no front brakes. Why? [Re: BigBlockMopar] #464080
09/09/09 09:03 PM
09/09/09 09:03 PM
Nebraska
mopar addict
mopar addict
Nebraska
ummmm...... better check that.
Vinny
Re: I have no front brakes. Why? [Re: BigBlockMopar] #464081
09/09/09 09:20 PM
09/09/09 09:20 PM
MNobody Offline
MNobody  Offline
Aren't the flare nuts on the lines 2 different sizes? I can't remember...
Re: I have no front brakes. Why? [Re: MNobody] #464082
09/09/09 10:15 PM
09/09/09 10:15 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
is it a prop valve or a distribution block? if its a prop valve sounds like its tripped and the valve is only letting fluid go to the rear.
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: I have no front brakes. Why? [Re: FASTBACK66] #464083
09/09/09 10:17 PM
09/09/09 10:17 PM
Nebraska
mopar addict
mopar addict
Nebraska
That was it. Thank you.
vinny
Re: I have no front brakes. Why? [Re: MNobody] #464084
09/09/09 10:19 PM
09/09/09 10:19 PM
Nebraska
mopar addict
mopar addict
Nebraska
yes they are but we were bleeding the wrong line when it was on the car.
Vinny
Re: I have no front brakes. Why? [Re: pnypwr] #464085
09/09/09 10:20 PM
09/09/09 10:20 PM
Nebraska
mopar addict
mopar addict
Nebraska
How can you visually tell the difference between the two??
Vinny
Re: I have no front brakes. Why? [Re: FASTBACK66] #464086
09/09/09 10:30 PM
09/09/09 10:30 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
prop valves usually have a switch for a light! a dist block just has in and out like a tee
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
