Are 2 & 4 Door Bench Seat Tracks The Same? #463990
09/09/09 03:49 PM
09/09/09 03:49 PM
Newburgh, NY
Old_Moparz Offline OP
Newburgh, NY
I never got the seat tracks & the related hardware with the bench seat for my 1968 Coronet 500 convertible & need to find a complete set up to install the seat. I need both the left & right tracks, along with the adjusting lever & the cable, but I was wondering if these items are the same for the 2 door & 4 door cars. It would widen my search & I would assume they are the same, but does anyone know for sure?
Thanks.
Re: Are 2 & 4 Door Bench Seat Tracks The Same? [Re: Old_Moparz] #463991
09/09/09 05:27 PM
09/09/09 05:27 PM
MNobody Offline
MNobody  Offline
I believe they are different.
Silly me i was thinking Bench seat, Bucket seat are different.
Re: Are 2 & 4 Door Bench Seat Tracks The Same? [Re: Old_Moparz] #463992
09/09/09 05:31 PM
09/09/09 05:31 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
I used a driver seat and tracks from a 1968 Coronet 500 4door in my 68 Coronet R/T, everything matched exactly!
Re: Are 2 & 4 Door Bench Seat Tracks The Same? [Re: Old_Moparz] #463993
09/09/09 06:18 PM
09/09/09 06:18 PM
O
OLD318 Offline
OLD318  Offline
O
on a 68-70 B-Bodies the two door and 4 door tracks are different. Check your parts books. They all have Different part numbers.
Re: Are 2 & 4 Door Bench Seat Tracks The Same? [Re: OLD318] #463994
09/10/09 12:27 AM
09/10/09 12:27 AM
Indiana USA
DBishop68 Offline
DBishop68  Offline
Indiana USA
4 door tracks work but are almost one inch taller
Re: Are 2 & 4 Door Bench Seat Tracks The Same? [Re: Old_Moparz] #463995
09/10/09 10:14 AM
09/10/09 10:14 AM
Newburgh, NY
Newburgh, NY
If the difference is only the height by an inch, then I think I can live with that since I'm only 5'-10" tall & I can put the top down too.
Thanks for the replies.
Re: Are 2 & 4 Door Bench Seat Tracks The Same? [Re: Old_Moparz] #463996
09/10/09 10:12 PM
09/10/09 10:12 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Some have a cable that runs from adjuster to adjuster across the floor of the car. As you pull the handle the cable unlocks a ratcheting pawl on the other adjuster. You may need to do something to shorten or lengthen the cable depending on which way you're swapping..
Re: Are 2 & 4 Door Bench Seat Tracks The Same? [Re: Sixpak] #463997
09/11/09 10:21 AM
09/11/09 10:21 AM
Newburgh, NY
Newburgh, NY
Thanks for that tip, it should be simple to correct if I have to.
