46 Plymouth wheels ??? #463806
09/09/09 10:26 AM
09/09/09 10:26 AM
Anonymous OP
Anonymous OP
I have the original front end on my coupe. Can some one tell my what wheels will fit it. I have a Mustang rear end under it. Thanks RUSTY
Re: 46 Plymouth wheels ??? #463807
09/09/09 11:29 AM
09/09/09 11:29 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
5 on 4.5 wheels (Mopar, Ford) will fit. You will have to make sure the center register will work.
There also may be a pin sticking out that could interfere with some wheels.
If the rear is a 5 lug Mustang not a MII or fox body one, it will have the same pattern.
Re: 46 Plymouth wheels ??? [Re: RodStRace] #463808
09/09/09 11:35 AM
09/09/09 11:35 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Yeah the pin was there to hold the rim to install those dang lug bolts.We have Ford rims on the 41 parts car.Rocky
Chrysler Firepower
Re: 46 Plymouth wheels ??? [Re: therocks] #463809
09/10/09 08:57 AM
09/10/09 08:57 AM
moparx Online content
moparx  Online Content
here is a tip for those "lug bolts". get another hub/drum for the right side [the driver's side is left hand thread as i recall], then use 2" long "button head" capscrews that are threaded the whole length with a little thread locker[blue] - viola,instant "modern" studs. or use moroso,summit, etc. wheel studs. they may need a slight trimming on the heads and the length may need trimmed also [if you don't need the whole 3" length].
