Re: do i need my ecu
[Re: jbcuda]
#463774
09/09/09 10:57 AM
09/09/09 10:57 AM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
thanks so can i just remove the ugly plug for it and tape it up what about the ballast resistor is it a necessity
RTFM!!!(that means check your instructions..
[Re: jbcuda]
#463775
09/09/09 03:41 PM
09/09/09 03:41 PM
DaytonaTurbo
Manitoba, Canada
Remove the ballast and use a wire to connect the ends together to bypass it.
[Re: DaytonaTurbo]
#463776
09/09/09 04:38 PM
09/09/09 04:38 PM
RemCharger
Sk. Canada
Ummmm doesn't it depend on what type of coil you have? Or does going to a 6al make the coil need more voltage...
[Re: RemCharger]
#463777
09/09/09 05:55 PM
09/09/09 05:55 PM
Posts: 15,491 the boonies
aarcuda
the boonies
the coil gets its power and from the MSD box. the 12v from IGN on only turns the box on and off. the coil voltage comes from a big transformer in the MSD box which gets its main power from a separate power lead (not the 12v ign power).
So the ballast resistor does NOTHING
[Re: DaytonaTurbo]
#463780
09/09/09 07:09 PM
09/09/09 07:09 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
MSD system doesn't require ballast to coil because the coils is not getting anymore constant power on each spark pulse making it heat. Being now MULTIspark, won't get power constantly to get heated and damaged. Gets some cold between spark to keep it safe
