Eagle or K1 rods? #463453
09/08/09 10:33 PM
09/08/09 10:33 PM
Lexington,VA
68gtxsurvivor Offline OP
Lexington,VA
Looking at H beam rods for my 505 stroked 440. Whats the best rod I can get without going aluminum. My 440 source rod ruined my block all rods, crank and one indy head so im definetly not going that route again.
Re: Eagle or K1 rods? [Re: 68gtxsurvivor] #463454
09/08/09 11:05 PM
09/08/09 11:05 PM
i sell both, but i prefer the K-1's. if i can help, PM me.
Re: Eagle or K1 rods? [Re: 68gtxsurvivor] #463455
09/08/09 11:07 PM
09/08/09 11:07 PM
Hemiroid Offline
Hemiroid  Offline
Olivers
Re: Eagle or K1 rods? [Re: Hemiroid] #463456
09/08/09 11:18 PM
09/08/09 11:18 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Oliver, Howards, Crower, K1, King, Lentz, Compstar, Corillo, Manley, childs and alberts,
All are GREAT rods,
Eagle, scat, lunati, are all good rods...
We had Oliver Rods in our 588, It was a good piece, Someone out there has it now in an avenger, and I was told its haulin ass again. My buddy has King rods in his late model, and it takes 30+ laps of 8000-idle-8000 rpm and still kicks it hard.
Re: Eagle or K1 rods? [Re: 68gtxsurvivor] #463457
09/09/09 12:49 AM
09/09/09 12:49 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Going on 8 1/2 years w/chevy style 6.385 eagles and will re-use em again w/new bolts and a re-hone.
Re: Eagle or K1 rods? [Re: Thumperdart] #463458
09/09/09 10:20 AM
09/09/09 10:20 AM
Canada
RobR Offline
RobR  Offline
Canada
Oliver billet are my first choice...I use a lot of K1's but I don't reuse them when an engine comes in for a freshen
Re: Eagle or K1 rods? [Re: RobR] #463459
09/09/09 10:28 AM
09/09/09 10:28 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
I'm using some of Ohio Crankshaft's heavy duty i-beams in my big block. Very nice rods and needed no extra work.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Eagle or K1 rods? [Re: Moparnut426] #463460
09/09/09 10:35 AM
09/09/09 10:35 AM
Boise
Moparteacher Online content
Moparteacher  Online Content
Boise
Don't forget Cunningham rods.
Re: Eagle or K1 rods? [Re: Moparteacher] #463461
09/09/09 02:40 PM
09/09/09 02:40 PM
Lexington,VA
Lexington,VA
Where can I pickup the ohio crank I beams and whats the cost
Re: Eagle or K1 rods? [Re: 68gtxsurvivor] #463462
09/09/09 07:14 PM
09/09/09 07:14 PM
you can pick them up from ohio crankshaft.
it would be wise to have your machinist disassemble them, reassemble, stretch the bolts to spec. for whatever bolts they come with and then check them for size and roundness.
DAMHIK
Re: Eagle or K1 rods? #463463
09/10/09 02:04 AM
09/10/09 02:04 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
We have K1 rods and crank in our 7 second street C-body. Have been in use for three years now, so far so good. We must be making well over 1000 hp.
Plynouth VIP '67 TT IC EFI
Re: Eagle or K1 rods? [Re: jyrki] #463464
09/10/09 05:57 AM
09/10/09 05:57 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Man I have been out of the loop for a while, when did Ohio start making rods? Or are they re-packaged something-elses?
Re: Eagle or K1 rods? [Re: CokeBottleKid] #463465
09/10/09 06:47 AM
09/10/09 06:47 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
I'm pretty sure every shop that makes an h-beam rod all has the same supplier they just finish machine the rods and add bolts. Ohio's I-beam rods though I guess are stamped in house or Ohio has another company make them. I did have mine checked after I stretched the bolts a couple of times, they did not need any honing done. I have two full seasons on them now. K1 is a great rod as well and Dram can fix you up on those.
14x Track Champ
Re: Eagle or K1 rods? [Re: Jacob Pitt] #463466
09/10/09 09:21 AM
09/10/09 09:21 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
No way. A couple of years ago there were pictures posted of a bunch of different brand H beams and there were obvious differences between many of them. They were ALL forged in China. Some were machined in china, some in USA.
Re: Eagle or K1 rods? [Re: GomangoCuda] #463467
09/10/09 10:12 AM
09/10/09 10:12 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
That is what I meant, they all get them from the same place and machine them in house.
14x Track Champ
Re: Eagle or K1 rods? [Re: Jacob Pitt] #463468
09/10/09 11:29 AM
09/10/09 11:29 AM
GomangoCuda Offline
GomangoCuda  Offline
If someone can repost or link to the pics you will see that they are not the same forging.
Re: Eagle or K1 rods? [Re: Jacob Pitt] #463469
09/10/09 12:23 PM
09/10/09 12:23 PM
Moparnut426 Offline
Moparnut426  Offline
Are youguys sure about that,,,
The compstar H beams, The K1, and Manley H beams look way different than the eagles, scat, and cat rods..
Im no expert, but I have looked them over pretty hard side by side here at the local machine shop..
Kasey
Re: Eagle or K1 rods? [Re: Moparnut426] #463470
09/10/09 12:33 PM
09/10/09 12:33 PM
GomangoCuda Offline
GomangoCuda  Offline
You can add 440 Source to that list. I think you may find differences in all of the rods mentioned so far. There is NOT just one factory forging every Chinese rod.
Re: Eagle or K1 rods? [Re: GomangoCuda] #463471
09/10/09 01:19 PM
09/10/09 01:19 PM
Lexington,VA
Lexington,VA
What would you guys use? K1 H beams or ohio cranks I beams. 505 ci 440 11 to 1 comp. indy -1's
Re: Eagle or K1 rods? [Re: 68gtxsurvivor] #463472
09/10/09 02:25 PM
09/10/09 02:25 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
They are both great rods that would live forever in this motor. Here is a link to the Ohio rods.http://ohiocrank.com/ibeam_rods.html
14x Track Champ
