priming my engine before start up? #463342
09/08/09 08:47 PM
09/08/09 08:47 PM
montreal, quebec, canada
jimmy71demon Offline OP
is there a difference betweeen priming ur engine with a drill, and jus turning it over with no fire or fuel pump? what is the proper way to prime an engine before start up?
thanks in advance
jimmy
Im goin fast Mom!
Re: priming my engine before start up? [Re: jimmy71demon] #463343
09/08/09 08:51 PM
09/08/09 08:51 PM
MNobody Offline
MNobody  Offline
With a drill and a priming rod.
Re: priming my engine before start up? [Re: jimmy71demon] #463344
09/08/09 08:53 PM
09/08/09 08:53 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
You take the dist to oil pump drive gear out of the motor and stick a oil pump priming rod in the oil pump and spin it with drill. Do that first and then turn the motor over by hand while spinning the drill motor and then youre done. Put it back togeather and start it.
There's three different ones in this picture for a Mopar. The one with yellow tape on it is homemade fron a peice of 1/4" chrome moly tubing. It's primed a bunch of 3000HP hemis with 60W oil.
Adj push rod and primer tool for Chev too.
Re: priming my engine before start up? [Re: jimmy71demon] #463345
09/08/09 10:46 PM
09/08/09 10:46 PM
Take out dist/intermediate shaft, Home Depot has a 5/16" paint stirrer shaft for cheap. Take out/off the plugs/valve covers & have someone turn the crank slowly w a breaker bar & 1&1/4 socket while you man the drill up top until both rocker arm assy's get their oil. Then I take off the rocker arm assy's & (re)goop up the lobes/lifter bottoms then bolt the rocker arm assys back on to make sure I have PLENTY for startup and that too much didn't get wiped off in the crank turning ordeal. A bit excessive maybe but after thousands in time/money into it getting a bit anal at the very end doesn't bother me especially when it's SO close to fireup time. EDIT On your bench grinder trim/smooth several inches of the rod & wrap it w black electrical tape where it goes thru the bronze bushing to protect it.
Re: priming my engine before start up? [Re: RapidRobert] #463346
09/09/09 01:20 AM
09/09/09 01:20 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Get one of these at Summit Racing for $7.88
http://www.summitracing.com/parts/DCC-4286800/?image=large
Mark where the rotor is pointing so you can put it back in the same location. Pull the dist and drive under it.
Insert the tool hooked to a drill that runs in the direction the dist usually turns.
Run the drill in the correct direction while cranking the engine with the starter.
When you see oil from the rockers you're done. I don't pull the valve covers, just look through the oil fill hole.
Re: priming my engine before start up? [Re: Lefty] #463347
09/09/09 02:22 AM
09/09/09 02:22 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
I prefer drill prime too.
The reason you stay away from the starter is it may take hundreds of revolutions of the engine to build oil pressure with the starter. In the meantime your bearings recieved no oil. Nothing up to the rockers yet either, which also means no drainback. So the camshaft lobes are dry too.
Now even with the perfect prime. The cylinder walls are not all lubed and the connecting rod small end (wrist pins)are still not lubed.
This is why after priming, it is essential to get the engine to fire up on the first hit.
Have the distributor pointed correctly and the carburetor bowls filled.
Re: priming my engine before start up? [Re: Magnum] #463348
09/09/09 02:38 PM
09/09/09 02:38 PM
thanks guys! u see my buddy and i both did rebuilds this summer for the first time. him a pretty much stock rebuild on a 318, and me a 416 stroker. thats y i have been asking a lot of "newbie" questions cause we both want to be sure of what we are doing. neither one of us really had the money to do it in the first place, so we definatly cant afford to start all over again! but i (we) really appreciate all the input and information from u guys. when ever we get snagged or stumped this is the first place i come to get answers!
party on Wayne!
Im goin fast Mom!
Re: priming my engine before start up? [Re: jimmy71demon] #463349
09/09/09 06:22 PM
09/09/09 06:22 PM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
On new engines, I drill prime mine while its stil on the stand with the intake and valve covers off. I can see whats going on and make sure oil is getting everywhere it needs to. After the engine is in and she is ready to go, I prime her again for a min or so, button her up and lite the fires. The only time I touch the starter is to lite her up. Dont want to spin it over on "dry" bearings. Also, when you do it on the stand, you can check your pan and lower seals for any type of leakage.
Good luck with the new engines and enjoy them.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: priming my engine before start up? [Re: StandOnIt] #463350
09/09/09 06:47 PM
09/09/09 06:47 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Also, remember when you put the primer rod in your drill to set your drill to reverse. Looking down on it from the top the pump spins counter clockwise.
Re: priming my engine before start up? [Re: DaytonaTurbo] #463351
09/09/09 08:35 PM
09/09/09 08:35 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
But Jimmy's doing a small block, man! clockwise
Re: priming my engine before start up? [Re: Lefty] #463352
09/09/09 11:40 PM
09/09/09 11:40 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
That Summit/MP piece .... NOTHING more than a simple 5/16 hex steel stock ... but something a BUNCH best-er .. a steel or even an aluminum rod with a plastic PVC coating on-it to protect the bushing.
Electrical or duct-tape aint gonna cut-it !!
Re: priming my engine before start up? [Re: buildanother] #463353
09/10/09 12:13 AM
09/10/09 12:13 AM
Manitoba, Canada
Manitoba, Canada
Sorry, my bad, clockwise on the small blocks, counter clockwise on the big blocks.
Re: priming my engine before start up? [Re: DaytonaTurbo] #463354
09/10/09 12:39 AM
09/10/09 12:39 AM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
we primed a big block with one of those differential lube pumps, stuck the plastic tube with no tip in the threaded oil filter boss (fit pretty good) and pumped..and pumped. We actualy got a reading on our oil pressure guage and oil up top in the rockers. Spun a full filter on and kicked her over. Ghetto, but I think it worked...It was sunday night and no place was open to buy the 5/16 hex shaft.
12 Grand Caravan
06 T&C
02 T&C
96 Breeze
65 Barracuda "S"
Re: priming my engine before start up? [Re: pishta] #463355
09/24/09 09:10 PM
09/24/09 09:10 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Last time I fired a new engine I primed it on the stand. Saw 2 black flakes come out of the head. I was able to grab them!
Too bad a slant can't be primed like a V-8. I guess you just pack the pump with Vasoline.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: priming my engine before start up? [Re: Rug_Trucker] #463356
09/25/09 10:02 AM
09/25/09 10:02 AM
hey thatks guys i really appreciate the input. this is my first rebuild so im trying to get all the info i can!
Im goin fast Mom!
