Re: SB MOPAR 360/408 EAGLE 4.00" CAST STEEL CRANK??????????
[Re: RAY1969CARS]
#463051
09/08/09 02:50 PM
09/08/09 02:50 PM
Look around the forged ones are around $500 range--they are easy to balance and that saves the diff in $$ usually making it a wash--some rod piston combos come up pretty easy with the cast but it is a crap shoot--could need Mallory metal or expensive flexplate etc--On the other hand I have made lots of them with cast and never had a problem but forged is better in the end IMO
[Re: RAY1969CARS]
#463053
09/08/09 03:27 PM
09/08/09 03:27 PM
Not Eagle but i ran the Mopar cast in my 416,taking it to 7000 rpms several times with no issues,they were $400 when i built mine i think you can get them cheaper now..by the way the 416 made 520 h.p. and 500 lbs of tq...
[Re: 70AARcuda]
#463056
09/08/09 04:08 PM
09/08/09 04:08 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
My mopar cast and forged 4 inch cranks both have the SCAT logo on them
yuph...scat made them for mopar ...
Even the big $$$$ billets. Mine doesn't have any logo on it.
[Re: S/ST 3040]
#463057
09/08/09 05:12 PM
09/08/09 05:12 PM
Posts: 830 east coast
Otherlane
east coast
I ran the mopar cast 4 in crank when they first came out 414 13 to 1 motor that saw 7000 rpm for 3 years without problems.the car ran 10.50@3300 pounds
#463059
09/08/09 06:09 PM
09/08/09 06:09 PM
Quicktree
how long did that motor last? just curious
[Re: Quicktree]
#463060
09/08/09 06:53 PM
09/08/09 06:53 PM
Motor lasted 2 seasons until a ROD BOLT SNAPPED!!! ARP too...
#463062
09/08/09 07:24 PM
09/08/09 07:24 PM
Posts: 2,709 NJ central
Scamp408
NJ central
What Rods?
[Re: Scamp408]
#463063
09/08/09 07:25 PM
09/08/09 07:25 PM
S/ST 3040
What Rods?
#463066
09/08/09 08:08 PM
09/08/09 08:08 PM
Quicktree
yea right 2 seasons how many pases? the cheap SIRS you put in there is what broke. that and the 7000 rpms
[Re: 80arrow]
#463068
09/08/09 08:58 PM
09/08/09 08:58 PM
Posts: 1,489 St. Louis Mo.
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
I ran my 410 cast crank with all transbrake launchs4000, 6800 shifts .Don't remember what rods ,arp bolts ,in the OHIO CRANK kit ,replaced crank too much alky oil then replaced with mopar C.C till death last year at MMW about 6 years of bracket racing for pts . Stepped up this year callies,probe pistons. long run get forged crank don
2009 418" build dan smith built
new 9.96 131.82
6.23 108
1.30 60 foot
best to date 9/15/09
8in 727 430 dana 2860 lb 3040 lb w driver
[Re: 10 o to go]
#463069
09/08/09 10:24 PM
09/08/09 10:24 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
I bought a cast one for a 408ci interim motor for my F.A.S.T. Duster. It took me to 11.90 @ 114 which was very good considering how we had to run. I wrung it only to 6200 or so. The amount of meat in the arm between the 7/8 journal and the rear main bearing journal was scary to look at but didn't cause an issue.
One very nice positive is that it didn't need any mallory to internally balance. I ran Eagle H beams and SRP forgings.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
