Valve spring installed height on stock BB castings #463032
09/08/09 12:50 PM
09/08/09 12:50 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
What is the usual installed height for valve springs on stock BB castings with stock length valves?
I ask because I have a set of roller springs that installed a 1.900 will coil bind at max lift, but if installed at 1.950 will be OK.
Im in the mock up stage so I havent tried them at 1.950, but wondering about retainer to rocker clearance at 1.950
Anyone?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Valve spring installed height on stock BB castings [Re: Von] #463033
09/08/09 01:56 PM
09/08/09 01:56 PM
Longview, Texas
marvo451 Offline
marvo451  Offline
Longview, Texas
Typically stock installed height is in the 1.86-1.88 range. To get 1.95 you may have to cut the spring pockets deeper, or use different locks and/or retainers to gain more height.
Re: Valve spring installed height on stock BB castings [Re: marvo451] #463034
09/08/09 03:41 PM
09/08/09 03:41 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I don't recommend cutting into the head. Use dished retainers.
Re: Valve spring installed height on stock BB castings [Re: MoparforLife] #463035
09/09/09 12:47 AM
09/09/09 12:47 AM
use +.050 retainers and +.050 keepers
Re: Valve spring installed height on stock BB castings [Re: Cab_Burge] #463036
09/09/09 02:02 AM
09/09/09 02:02 AM
and then make sure you don't have interference between the rocker and the retainer. also pray that the 40 year old heads haven't had the valves tipped so much that the +.050 locks and retainers aren't going to sit above the stem.
Re: Valve spring installed height on stock BB castings #463037
09/09/09 08:15 PM
09/09/09 08:15 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
And that the lash caps (might need them to get that rocker-retainer clearance) don't bottom out on the locks.
