Re: HELP smog 440 needs a cam change
[Re: RemCharger]
#462551
09/08/09 11:44 AM
09/08/09 11:44 AM
Posts: 5,166 CT
GTX MATT
CT
The resto cam and a set of headers would wake it up alot.
[Re: RemCharger]
#462552
09/08/09 12:29 PM
09/08/09 12:29 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
If you want cheap just to run try Summits cams.The larger one runs real well.If you are rebuilding the other motor and just want to get by they cant be beat.Like around 100 for cam and lifters.Rocky
Chrysler Firepower
[Re: therocks]
#462553
09/08/09 12:55 PM
09/08/09 12:55 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
cheap, the larger summit cam and the comp 911 springs. if you want to make more torque to better fit your converter and gears while making similar HP, I'd look at the Lunati voodoo 60302 and the comp 911 springs
[Re: therocks]
#462556
09/08/09 06:16 PM
09/08/09 06:16 PM
Posts: 352 Arizona
69rrgrabber
Arizona
I'm about to use that big summit cam too. Anyone know if the stock 11 inch converter will work well with this cam or will it need a higher stall?
Thanks, CAC
"It takes a Mopar to catch a Mopar!"
1969 Charger R/T 440
1969 Road Runner 383
1970 Cuda 440
[Re: 69rrgrabber]
#462557
09/08/09 08:18 PM
09/08/09 08:18 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
I'm running the smallest Summit cam in my 75 .030 440 block, steel crank from a 70 block, KB pistons with .044 quench with 915 heads and 4:11 gears in this..........
Moparlee
