HELP smog 440 needs a cam change #462548
09/07/09 08:31 PM
09/07/09 08:31 PM
kansas
N
nic Offline OP
nic  Offline OP
N
kansas
I have a 72 rallye charger that has a wounded 400. I am going to temporarily drop in a 75' 440 from a pickup until I can rebuild the 400. The 440 doesn't need to be rebuilt but I would like to slide in a better cam to wake it up a bit. Has anyone gotten good performance from a smogger with a simple cam change ?? The gears are 2.76 and it does have a small 2000 stall converter ,,,, everything else is stock.. Any ideas ????
Re: HELP smog 440 needs a cam change [Re: nic] #462549
09/07/09 08:44 PM
09/07/09 08:44 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Yep, some have gotten decent performance out of the smogger 440's...
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Although not with 2.76 gears.
Re: HELP smog 440 needs a cam change [Re: nic] #462550
09/07/09 08:46 PM
09/07/09 08:46 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Look at the 440 smogger thread in the archived section. I ran the .528 mech and ran mint(12 flat). I chose it due to the 60* overlap for building cyl press. IMO the 509 is too big(72*)... but others will attest that its worked for them...
Re: HELP smog 440 needs a cam change [Re: RemCharger] #462551
09/08/09 11:44 AM
09/08/09 11:44 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
The resto cam and a set of headers would wake it up alot.
Re: HELP smog 440 needs a cam change [Re: RemCharger] #462552
09/08/09 12:29 PM
09/08/09 12:29 PM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
If you want cheap just to run try Summits cams.The larger one runs real well.If you are rebuilding the other motor and just want to get by they cant be beat.Like around 100 for cam and lifters.Rocky
Chrysler Firepower
Re: HELP smog 440 needs a cam change [Re: therocks] #462553
09/08/09 12:55 PM
09/08/09 12:55 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
cheap, the larger summit cam and the comp 911 springs. if you want to make more torque to better fit your converter and gears while making similar HP, I'd look at the Lunati voodoo 60302 and the comp 911 springs
2017 Grand Cherokee Overland
Re: HELP smog 440 needs a cam change [Re: patrick] #462554
09/08/09 01:29 PM
09/08/09 01:29 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Larger Summit cam is a nice piece for the $$$ even the smaller one would wake it up. As mentioned headers and a little more gear would help a TON.
Coming soon!!!!
Re: HELP smog 440 needs a cam change [Re: patrick] #462555
09/08/09 01:46 PM
09/08/09 01:46 PM
kansas
N
nic Offline OP
nic  Offline OP
N
kansas
Thanks for the advice to all ! I actually do have the bigger summit cam on the shelf,,, I had it in the 400 for a while but it didn't make much torque down low so i switched it out. But maybe it will work better with the 440's longer stroke ? I am going to install a set of shorty headers also.
Re: HELP smog 440 needs a cam change [Re: therocks] #462556
09/08/09 06:16 PM
09/08/09 06:16 PM
Arizona
69rrgrabber Offline
69rrgrabber  Offline
Arizona
I'm about to use that big summit cam too. Anyone know if the stock 11 inch converter will work well with this cam or will it need a higher stall?
Thanks,
CAC
"It takes a Mopar to catch a Mopar!" 1969 Charger R/T 440 1969 Road Runner 383 1970 Cuda 440
Re: HELP smog 440 needs a cam change [Re: 69rrgrabber] #462557
09/08/09 08:18 PM
09/08/09 08:18 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
I'm running the smallest Summit cam in my 75 .030 440 block, steel crank from a 70 block, KB pistons with .044 quench with 915 heads and 4:11 gears in this..........
Moparlee
