440 crank removal question #462540
09/07/09 08:30 PM
09/07/09 08:30 PM
SW Fla.
CYACOP Offline OP
CYACOP  Offline OP
SW Fla.
How do I remove the rear seal housing so I can get the crank out?
Re: 440 crank removal question [Re: CYACOP] #462541
09/07/09 08:35 PM
09/07/09 08:35 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Take the 2 bolts out of the aluminum retainer....then the main caps..
Re: 440 crank removal question [Re: CYACOP] #462542
09/07/09 08:36 PM
09/07/09 08:36 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Taki out the 2 bolts and remove the seal retainer. 7/16 thin wall socket. (maybe 3/8 socket )
Re: 440 crank removal question [Re: MoparforLife] #462543
09/07/09 08:46 PM
09/07/09 08:46 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
12 point thin wall socket.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: 440 crank removal question [Re: MoparforLife] #462544
09/07/09 08:47 PM
09/07/09 08:47 PM
SW Fla.
CYACOP Offline OP
CYACOP  Offline OP
SW Fla.
Thats what I figured but I cant seem to get a 1/4 drive socket in there that will grip it, I cant see a hex on the bolts.
Re: 440 crank removal question [Re: CYACOP] #462545
09/07/09 08:49 PM
09/07/09 08:49 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Must be a 12 pt and get the slicone outta there, spray it with cleaner you'll see it....
Re: 440 crank removal question [Re: QuickBpBp] #462546
09/07/09 08:52 PM
09/07/09 08:52 PM
IA
landon1 Offline
landon1  Offline
IA
12 pt 3/8"
'71 Satellite Sebring 440
Re: 440 crank removal question [Re: QuickBpBp] #462547
09/07/09 08:52 PM
09/07/09 08:52 PM
SW Fla.
CYACOP Offline OP
CYACOP  Offline OP
SW Fla.
Got it, 3/8 12 it is. Thank you genlemen.
