Re: engine guys, #3 bearing cap won't seat properly? [Re: gregsdart] #461829
09/07/09 09:41 PM
09/07/09 09:41 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
sorry Greg i'm running around like a madman trying to get ready for a trip to CA and wasn't paying attention when i posted the numbers. the housing bore is listed as 2.9425-2.9430. i don't think you usually move the crank up too much just bumping the mains with a hone but i've personally never performed this operation or payed attention. obviously it depends on what it takes to get it straight/round and to size. on the piston to head i'd be interested to see what people have to say. of course there are a number of factors. bore size, piston clearance, RPM, rod type etc. i'm wrestling with this issue on a new build because the pistons are .005 taller than i wanted. i'm at zero deck with a 4.5 crank, 7.1 olivers and fresh 4.44 bore. this is an aluminum block so i'm wondering if it will grow some and open this clearance up a little. at this point all my piston to head is going to be in the gasket so i may be limited on what i can do.
Re: engine guys, #3 bearing cap won't seat properly? [Re: jamesc] #461830
09/07/09 09:47 PM
09/07/09 09:47 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
With Cometics or copper gaskets piston to head shouldn't be an issue. Chose the right thickness and your good to go.
Doug
Re: engine guys, #3 bearing cap won't seat properly? [Re: dvw] #461831
09/07/09 10:08 PM
09/07/09 10:08 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Greg , is this still on the factory provided main line machining or did you have it redone ? I had a similar issue, stock 440 block , added studs and linebored for the studs because the torque spec for studs is greater than bolts. I put in the crank and it would lock up when #3 was torqued to spec, I hadn't opened the cap holes on #3 BEFORE the line bore, I ream to 17/32nd, I did it afterwards.
I finally figured out the cap was cut crooked by the shop , they all were, and it allowed the studs to straighten out the cap when torqued because the block side of the cap wasn't parallel to the spot face where the bolt/nut clamps against the cap.
Re: engine guys, #3 bearing cap won't seat properly? [Re: RonP] #461832
09/07/09 10:25 PM
09/07/09 10:25 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
I agree, with studs sometimes you need to clearance the bolt holes to get the caps to seat properly & with #3 being the thrust bearing it's more critical...
Had to do exactly that on mine. Been 3 years of beating since. Chuck at Best (his caps) had me open the holes in the cap some and all was well.
Yes indeed
Sometimes you can get away with it and other times At this point it should be manditory when studs replace the factory main cap bolts, the block be line honed and the #3 thrust cap be drilled out with a 17/32 drill. Chuck Senatore taught me this trick 15 years ago.
Re: engine guys, #3 bearing cap won't seat properly? [Re: JohnRR] #461833
09/08/09 12:18 AM
09/08/09 12:18 AM
gregsdart Offline OP
Caps were drilled to 17/32 by RBRE when they put in the stud kit, apparently. They did the original machine work. All holes are .531, which is 17/32.
DRAGRACER97 could not find any bolts to fit. This has been a studded block from day one. Hemi style bottom end, so it has to have longer bolts than I have in my possession.
Am going out to see what measurements are now on all main bores.
Re: engine guys, #3 bearing cap won't seat properly? [Re: gregsdart] #461834
09/08/09 12:34 AM
09/08/09 12:34 AM
Found these numbers.
Factory specs 2.9425 to 2.9430
Mine are;
#1 front side, 2.9425 back side 2.9431
#2 front side, 2.9427 back side 2.9430
#3 front side, 2.9421 back side 2.9428
#4 front side, 2.9434 back side 2.9427
#5 front side, 2.9434 back side 2.9435
Too much variance for my new crank to come home to. I think it is time for a line hone. The bearings always did come out of this motor with odd wear patterns, maybe this is why.
Re: engine guys, #3 bearing cap won't seat properly? [Re: gregsdart] #461835
09/08/09 01:07 AM
09/08/09 01:07 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Was this block line honed or checked when it was new? Sounds like it was not, or whoever line honed it did a poor job. If it has taper now, it had it then.
Monte
Re: engine guys, #3 bearing cap won't seat properly? [Re: gregsdart] #461836
09/08/09 01:09 AM
09/08/09 01:09 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Mine are;
I'd agree with you on that , something is just not right with those numbers
Re: engine guys, #3 bearing cap won't seat properly? [Re: JohnRR] #461837
09/08/09 01:14 AM
09/08/09 01:14 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I agree looks like it had taper from day one...Dont think you can do anything to cause that problem other than mis machined
Re: engine guys, #3 bearing cap won't seat properly? [Re: Al_Alguire] #461838
09/08/09 08:47 AM
09/08/09 08:47 AM
Thanks for the input , guys. Monte, this block was ordered with the stud kit installed, so a guy would hope they did it right. The caps and bores all show consistent hone marks. That would lead me to believe the stud kit may have been put in without a re hone?
Yep, it will get a line hone. Troubles that will pop up with that are loss of piston to head clearance, not a super big issue but another $150 for new gaskets. The milodon gear drive may be an issue though. Will have to check with them and see what can be done to make that fit again, as the holes for alignment are already in the block.
Re: engine guys, #3 bearing cap won't seat properly? [Re: gregsdart] #461839
09/08/09 08:55 AM
09/08/09 08:55 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Did you ever try checking it with a feeler or even torquing it with some shim under one side to see if it gets worse?.
I would verify that it was seated correctly before line boring.
Re: engine guys, #3 bearing cap won't seat properly? [Re: The Shadow] #461840
09/08/09 09:01 AM
09/08/09 09:01 AM
I checked and rechecked the mating surfaces, cleaned and double checked them. Numbers are from a very good dial bore gauge, all consistent after being checked multiple times.
Re: engine guys, #3 bearing cap won't seat properly? [Re: gregsdart] #461841
09/08/09 09:21 AM
09/08/09 09:21 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
If your happy with your results.
I was just offering a solution to check a stud bind issue.
How many years have you run the block?
Did it have oiling issues?
Re: engine guys, #3 bearing cap won't seat properly? [Re: The Shadow] #461842
09/08/09 10:55 AM
09/08/09 10:55 AM
this block has been around for a while, only 100 passes on it though since new. Thanks again, will re post after the trip to the machine shop with new numbers.
Re: engine guys, #3 bearing cap won't seat properly? [Re: gregsdart] #461843
09/08/09 12:19 PM
09/08/09 12:19 PM
Cab_Burge Online work
Cab_Burge  Online Work
Hopefully the machine shop will only remove the minmum(.002 to .003?) needed to make all of the mains rounds and straight
Re: engine guys, #3 bearing cap won't seat properly? [Re: The Shadow] #461844
09/08/09 04:53 PM
09/08/09 04:53 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Stud bind issue should be easy to spot , if you have to tap the cap to one side to pull the studs , I had to do that on the block I described above , the caps are cocked .
It's quite possible that somone swapped in the studs and didn't bother to rehone the block ?
Re: engine guys, #3 bearing cap won't seat properly? [Re: JohnRR] #461845
09/08/09 05:03 PM
09/08/09 05:03 PM
UK
602heavy Offline
602heavy  Offline
UK
Had this same problem regards crank endfloat on the megablock , drilled #3 cap & all was good.
Re: engine guys, #3 bearing cap **update** [Re: 602heavy] #461846
09/08/09 05:33 PM
09/08/09 05:33 PM
I don't want to throw anyone under the bus, but that thought crossed my mind. The other possibility is due to severe usage, stuff just moved. The problem with that idea is, I have two opinions i trust that don't think that happens.
Re: engine guys, #3 bearing cap won't seat properly? [Re: JohnRR] #461847
09/08/09 08:57 PM
09/08/09 08:57 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Same here. I even sent the #3 bearing back the first time.
I finally figured it out. Caps weren't trued up on the faces
before the caps were cut. When I'd torque #3, it would pinch
the crank between the thrust surfaces.
I pulled the bearing halves out, installed them, one at a time in the
cap and lapped them with 600 grit on a granite surface plate.
Re: engine guys, #3 bearing cap **update** [Re: gregsdart] #461848
09/15/09 09:09 AM
09/15/09 09:09 AM
Got the block back from the machine shop, and all bearing bores check within .0001 to .0002 on all five bearing bores, front to rear, and all are nice and round.
One discrepancy- my dial bore gauge was set to zero off a good mike, at 2.9425. Block came back tagged 2.9427 . I checked all bores, all measured +.0011 to +.0013, or a total of 9.436 to 9.437. I pulled another brand new mike out of its packing to double check my dial bore gauge, and came up with the exact same reading as the first mike. By setting the new mike to 9.425, it reads zero on the dial bore gauge same as the first mike.
Any input on the difference of measurements?
