engine guys, #3 bearing cap won't seat ? **update** #461809
09/07/09 01:36 PM
09/07/09 01:36 PM
gregsdart Offline OP
While measuring main bearings, # 3 came out with serious differences between the front side of the bearing and the back side. All measurments done at 12 oclock/six oclock, 90 degrees to the parting line. Front side, .0025. Back side, .004! Pulled the cap off, looked it over for obvious things like debris under the cap, a nick on the cap or block. I took the studs out and ran a stone over the mating surfaces lightly to see if anything showed up. Nothing. There is no material from cap walk affecting it, looks good. I tried another bearing, same readings. I pulled the cap off, and reset the dial bore gauge to that diameter, and got the same thing, back side over .001 too big. Checking the main bore, it is as if the cap is cocked in the block, the measurements taper perfectly from one side to the other. It actually measured .0017 difference. I am stumped. All readings done with studs torqued to spec. Any ideas?
Re: engine guys, #3 bearing cap won't seat properly? [Re: gregsdart] #461810
09/07/09 01:51 PM
09/07/09 01:51 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Could the holes in the cap be so tight that the studs are causing the cap to lean over? I would try a stock set of bolts. If the stud to hole clearance was close and the hole bores were not machined square it could force the cap out of position.
Doug
Re: engine guys, #3 bearing cap won't seat properly? [Re: dvw] #461811
09/07/09 01:55 PM
09/07/09 01:55 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Doug
I agree, with studs sometimes you need to clearance the bolt holes to get the caps to seat properly & with #3 being the thrust bearing it's more critical...
Re: engine guys, #3 bearing cap won't seat properly? [Re: 1_WILD_RT] #461812
09/07/09 01:58 PM
09/07/09 01:58 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
Doug
Had to do exactly that on mine. Been 3 years of beating since. Chuck at Best (his caps) had me open the holes in the cap some and all was well.
Re: engine guys, #3 bearing cap won't seat properly? [Re: RonP] #461813
09/07/09 02:03 PM
09/07/09 02:03 PM
Thanks much for the idea. How much did you have to open the cap holes?
Will check it out and let you guys know what I found!
Re: engine guys, #3 bearing cap won't seat properly? [Re: gregsdart] #461814
09/07/09 02:12 PM
09/07/09 02:12 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
I didn't have an exact amount. What I did (many times) is put some of that blue paste on the stud. I would seat the cap and then lok for contact spots. I took a small pencil grinder and just removed a little out of the hole. Did that many times until it fit. I probably don't qualify as an engine builder though having only assembled a few. Seemed to work ok for me though.
good luck
Re: engine guys, #3 bearing cap won't seat properly? [Re: gregsdart] #461815
09/07/09 02:16 PM
09/07/09 02:16 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
My buddy had a 17/32 drill bit so thats what I used..
Re: engine guys, #3 bearing cap won't seat properly? [Re: gregsdart] #461816
09/07/09 02:27 PM
09/07/09 02:27 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Greg,
The best way is to use an adjustable blade reamer. Done many this way. Very common problem. Surprised you didnt have thrust issues with the cap like that. You CAN drill it, especially if you have a good solid Bridgeport or drill press, but I have done both and I prefer the "dial in" ability of the reamer. Technichally the bolts dont do anything but provide the clamping force, and shouldnt even touch the cap, but you dont want to over bore the holes.The cap register provides the right fit. Good luck, hope it works out ok.
RIP Monte Smith
Re: engine guys, #3 bearing cap won't seat properly? [Re: CompWedgeEngines] #461817
09/07/09 03:29 PM
09/07/09 03:29 PM
Went out and measured the studs, and cap holes. Studs, .497.
Caps, .530 . Plenty of room in all directions, no binding. I looked at # 1 with the dial bore gauge and came up with results that are similar but not as bad. Also the minimum diameter of the # 1 bearing bore is .0005 looser than #3. I wire brushed the cap to clean off the cap walk gunk but it is still out of tolerance in my mind. Think it is time to have this block line honed. What do you guys think? I don't want to spin a bearing.
Re: engine guys, #3 bearing cap won't seat properly? [Re: gregsdart] #461818
09/07/09 04:00 PM
09/07/09 04:00 PM
you have plenty of bearing to crank clearences and(if) it has been running okay so far so it is uo to you, do what you thank is best
Re: engine guys, #3 bearing cap won't seat properly? [Re: Cab_Burge] #461819
09/07/09 04:14 PM
09/07/09 04:14 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I had the same thing on my last small block,I could not get the center 3 to sit flush, ended up with pro gram caps and line hone to the new caps
Re: engine guys, #3 bearing cap won't seat properly? [Re: emarine01] #461820
09/07/09 04:20 PM
09/07/09 04:20 PM
At this time I have more time than money, so I will do my best to get accurate data on where the bearing crush is, and decide from there. If that is in range or reachable I may try a back yard fix. Any input on that is appreciated!
Re: engine guys, #3 bearing cap won't seat properly? [Re: gregsdart] #461821
09/07/09 04:38 PM
09/07/09 04:38 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
The problem is not the actual clearance measured by the hole diameter vs stud diameter. The hole in the cap may not be consistent and it could be because the stud is not straight after seating in the block. It is very common to have problems when using studs. A bolt will not seat in the hole like a stud will. Think about it. The whole area in the block is threads and will come STRAIGHT out. A stud will not. My Machinist reamed out the holes in my main cap using a reamer. Makes a smoother hole but a drill would be fine. You have nothing to lost by drilling the hole one size larger. I bet that fixes it.
OR you can try intalling the cap temporarily with a BOLT and see what that does (re measure). If that fixes it then drilling the cap hole larger will almost for sure do it.
SRT DEMON ONE SEAT
Re: engine guys, #3 bearing cap won't seat properly? [Re: Ron Silva] #461822
09/07/09 04:42 PM
09/07/09 04:42 PM
Hemiroid Offline
Hemiroid  Offline
Had problems lots of times with studs. I would approach it this way if it were me. No sense driving yourself crazy and spending money if you don't have to
Re: engine guys, #3 bearing cap won't seat properly? [Re: Ron Silva] #461823
09/07/09 04:56 PM
09/07/09 04:56 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Before i would do anything I would check the bearing alignment in the block and cap for mislocated tangs before installing the crank and check for radius clearence on all the mains.Then install the #3 cap with the studs turned all the way in and backed out a 1/4 turn.Take a lead hammer and smack the crank for and aft checking the clearence at the main thrust on each side of #3 and check crank end play.Some times the thrust sides of the bearing need to be conformed to the cap and block.If this doesn't solve the issue then ream the cap holes as others have mentioned. We found a similar problem at #3 thrust and it was actually cause by #5 cap that the bearing was riding on the radius and creating the issue,that's why I suggest you check all mains.
Re: engine guys, #3 bearing cap won't seat properly? [Re: B G Racing] #461824
09/07/09 05:17 PM
09/07/09 05:17 PM
I tried different bearings, swapping halves to see if it were a bearing issue. It is definitely not the bearings, as the measurements came out differing the same when I measured the bores minus bearings. The back side was still .0015 larger. Plenty of room around the studs, checked for that and found the holes all consistantly .530, studs .497. The studs are perfectly centered, allowing cap placement way forward or backward to get proper bearing alignment of the #3. Plenty of room side to side as well.
Any one have the specs for max minimum bearing bore diameter for proper bearing crush? Standard rb bearings.
Re: engine guys, #3 bearing cap won't seat properly? [Re: gregsdart] #461825
09/07/09 07:51 PM
09/07/09 07:51 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
Greg you make no mention of what block this is (one you've been running?), mega, stocker? as others have mentioned studs can cause issues even if they're loose in the cap. 25 years ago i had a 340 that wouldn't even turn with studs. not knowing what to do or having the $$$ to hone it i put the bolts back in it. engine ran 11teens and is still together and running this day. just because the engine was correct before and ran OK doesn't mean things can't or won't move some. if you've measured the bores without bearings and are getting bad readings might be time to hone it. also remember even if the numbers are good doesn't mean the bores are in a straight line. the stock FM "book" spec for the bores is 2.9425-2.9430
Re: engine guys, #3 bearing cap won't seat properly? [Re: Cab_Burge] #461826
09/07/09 08:16 PM
09/07/09 08:16 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
I used a 17/32 reamer with a bridgport. all is good on mine...
Kasey
Re: engine guys, #3 bearing cap won't seat properly? [Re: jamesc] #461827
09/07/09 08:26 PM
09/07/09 08:26 PM
Jim the block is a megablock, the original block for this motor. Guess you are right, it may have shifted with use, especially with all the flex this thing has had. My biggest concern is I have fairly tight piston to head clearance as it is, and don't want to risk moving the crank up too much. I am at .046 with 6.965 steel h beams and about .001 oversize on piston to bore clearance with 4.500 pistons. I will have to call the shop tomorrow and see what they say. On the bearing bores, I was referring to the diameter without bearings installed. Looks to be about 2.940?
Re: engine guys, #3 bearing cap won't seat properly? [Re: gregsdart] #461828
09/07/09 09:00 PM
09/07/09 09:00 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
Please stick a couple bolts in there and torque to specs and remeasure. Then report back what you find.
SRT DEMON ONE SEAT
